Using IAP105 and IAP275 in Instant. Both have firmware 6.4 current. I see both units in Access Points with Mac Address. The IAP275 has a * at the end of the address. Have no wifi output on the IAP275. I'm betting I just need to enable something, but haven't figured it out. Thanks
No signal strength when I move from the 105 towards the 275.
Not sure how to 'show AP bss-table'
Have not configured as Air Monitor. Just matched the default of the 105
6.4.2.6-4.1.1.11_52666
Red Light on LED. Changed PoE to make sure that wasn't the problem
From the Virtual controller, you should be able to see the power and channel of both access points...
it shows IP address, Monitor ( even though set to access and rebooted twice), Mesh N/A, 275 type and ------- for everything else.
