last person joined: 9 hours ago
Need help with syslog message ID 341252 - VC delta config error
  • 1.  Need help with syslog message ID 341252 - VC delta config error
    Posted Apr 17, 2015 06:00 AM
    We have an Aruba Instant wifi network and the VC is continously generating the following syslog warning message "VC send delta configurations to ap error. ap <ap-IP-addr> ap_cfg_id 5 current_cfg_id 0 top_cfg_id 0 case out of range"
    The <ap-IP-addr> in each message is the address of each of the APs.
    The Aruba syslog reference manual lists this with message ID 341252 and has a description of "VC send delta configuration to ap error" but no explanation of what it may mean or why it may occur.
    Has anyone encountered this message before?
    If so, what type of problem does it indicate?
    Any help or insight that can be provided would be appreciated.
