Need mounting bracket in dropped ceiling
  • 1.  Need mounting bracket in dropped ceiling
    Posted Jun 29, 2020 01:48 PM
    We purchased an Instant On AP15.  I've done work with a few dropped ceilings but never seen this type.  What type of dropped ceiling bracket do I need to buy to mount AP15 into this ceiling?ceilingTile.PNG
  • 2.  RE: Need mounting bracket in dropped ceiling
    Posted Jun 30, 2020 07:16 AM
    It looks like you could use the ceiling rail mount that suits the 9/16ths rail. The rail should measure about 14mm. I'm not sure rail mounts come in the box with the AP15 but it does mention on the datasheet that ceiling rail mounts are included.
  • 3.  RE: Need mounting bracket in dropped ceiling
    Posted Jun 30, 2020 07:38 AM
    There are some mounts that may work from the Aruba line (not Instant On):
    AP-220-MNT-C2 (JW045A) - Silhouette.
    OR
    The more heavy-duty metallic mount AP-MNT-CM1(JX961A) can be adapted to the 9/16" Silhouette rail.
