Remote Access
last person joined: 8 days ago
Need Oath2 VB.net / C# prototype snippet for Aruba central api access
  • 1.  Need Oath2 VB.net / C# prototype snippet for Aruba central api access
    Posted Feb 16, 2021 10:07 AM
    Hello ,
    I am new to aruba networks, and are planning to become an integrator , need Oath2 VB.net / C# prototype snippet for Aruba central api access.
    Have been successfully doing api integration for Meraki, Solarwinds, et all. Need some quick help
    in  interacting with Aruba central networks, have all the Client secrets, Credentials, urls etc. Struggling a bit to get Access_Tokens, and Auth code after successfully geting CSRF TOKENS.
    Can connect to it via postman # Swagger, successfully  ​to retrieve AP's, Gateways , Switches etc.
    Please help.
    Mohan
    Mohan Deval
  • 2.  RE: Need Oath2 VB.net / C# prototype snippet for Aruba central api access
    Posted Jun 24, 2022 09:20 AM
    Hi you could use postman application to build that code. I am trying to do that... but even i follow all documentation it still gave me an error with "invalid Request body". If you get some results please write them here!
