Need the exact number of features IAP 93/105
  • 1.  Need the exact number of features IAP 93/105
    Posted Sep 11, 2013 03:07 AM
    How many exact number of Users, SSID, Mac entries, VLans are to be configured in the IAP 93/105 ?
    if there is a specific link where a correct information i can get, kindly provide me.
  • 2.  RE: Need the exact number of features IAP 93/105
    Posted Sep 11, 2013 05:19 AM
    Lets start from what i know.
    both ap's got 10/100/1000 eth port.
    ap-105 got dual radio dual band (so it can transmit up to 16 ssid 8 in 2.4 and 8 in 5)
    ap-93 got single radio dual band (so it can transmit up to 8 ssid's)
    cluster of ap-93 limited up to 16 units.
    cluster of ap-105 recommended up to 64 units.
    IAP-104, IAP-105, IAP-134, IAP-135, and IAP-175 support an unlimited (within reason...the usual L2 best practices apply of course...no free lunch)   number of IAPs on Layer 2 networks.
    IAP -92/93 supports 16 IAPs.
    read here also some info:
    http://community.arubanetworks.com/t5/Aruba-Instant/IAP-virtual-controller-max-capacity/td-p/35265
  • 3.  RE: Need the exact number of features IAP 93/105
    Posted Sep 11, 2013 12:47 PM
    Not only does 105's support 64, it has been QA'ed by Aruba to 64.
  • 4.  RE: Need the exact number of features IAP 93/105
    Posted Oct 21, 2013 07:01 AM
    this thread is a little bit older, but I wanted to point out that the Rel. 6.2 User Guide states:
    Number of WLAN SSIDs Supported
    By default, you can create up to six networks or WLANs. You can enable the Extended SSID
    option and create up to 16 WLANs. OAW-IAP-175, OAW-IAP-104, and OAW-IAP-105 devices
    support up to 8 SSIDs and RAP-3WN, OAW-IAP-92, OAW-IAP-93, OAW-IAP-134, and OAWAOS
    IAP-135 devices support up to 16 SSIDs. After you enable this option, the number of SSIDs that
    become active on each OAW-IAP depends on the OAW-IAP platform.
    So IAP105 supports 8 SSIDs all together instead of 8 per radio and IAP93 supports 16 SSIDs.
    Is this correct?
