last person joined: 5 hours ago
need to authenticate again after about 40 minutes
  • 1.  need to authenticate again after about 40 minutes
    Posted Jun 27, 2014 10:33 AM
    i remarked that an authenticated (by Clearpass) endpoint (let's say an iphone) looses it's authentication role after some time (i noted 40 minutes now).  I see on the controller it now only has an initial logon role, which caused ofcourse Clearpass to reject (if we just ask an app like twitter for example to update it's feed) as we did not re-authenticate  I still see the endpoint age at 40 mins at the controller, so the entry has not dissappeared from the controller.  It's just the role which has changed.  If we re-authenticate all's fine ofcourse.  Is there a timeout value somewhere at the controller level?
  • 2.  RE: need to authenticate again after about 40 minutes
    Posted Jun 27, 2014 11:07 AM
    In the user role, there is a "reauthentication interval" parameter.  See if that has anything.
  • 3.  RE: need to authenticate again after about 40 minutes
    Posted Jun 27, 2014 11:42 AM
    It's currently set to 0.  Any recommendation?
  • 4.  RE: need to authenticate again after about 40 minutes
    Posted Jun 27, 2014 11:47 AM
    Yes.  Turn on user debugging.  When the problems happens, look at the log to see why the user changed roles:
    config t
    logging level debugging user
     After the problem happens, type "show log user all" to see why the user disconnected.  That is the most definitive way to find out what is happening.
  • 5.  RE: need to authenticate again after about 40 minutes
    Posted Jun 27, 2014 12:03 PM
    Change the re authentication parameter to be something you want and use the debug to see whatis happening
  • 6.  RE: need to authenticate again after about 40 minutes
    Posted Jul 02, 2014 07:23 AM
    Have enabled the user debugging :
    Jul 2 10:01:00 2014 TEST-BE-002 authmgr[1655]: <522038> <INFO> <TEST-BE-002 172.16.101.252> username=xyz MAC=90:b9:31:34:99:99 IP=172.16.103.110 Authentication result=Authentication Successful method=radius-accounting server=TEST-BE-003
    Jul 2 10:04:16 2014 TEST-BE-002 stm[1666]: <501102> <NOTI> <TEST-BE-002 172.16.101.252> Disassoc from sta: 90:b9:31:34:99:99: AP 172.16.212.89-18:64:72:69:4f:3b-AP105-100 Reason STA has left and is disassociated
    Jul 2 10:04:16 2014 172.16.212.89 stm[1145]: <501102> <NOTI> |AP AP105-100@172.16.212.89 stm| Disassoc from sta: 90:b9:31:34:99:99: AP 172.16.212.89-18:64:72:69:4f:3b-AP105-100 Reason STA has left and is disassociated
    Jul 2 10:04:16 2014 TEST-BE-002 authmgr[1986]: <522036> <INFO> <TEST-BE-002 172.16.101.252> MAC=90:b9:31:34:99:99 Station DN: BSSID=18:64:72:69:4f:3b ESSID=test-guests-test VLAN=102 AP-name=AP105-100
    Jul 2 10:04:33 2014 172.16.212.89 stm[1145]: <501106> <NOTI> |AP AP105-100@172.16.212.89 stm| Deauth to sta: 90:b9:31:34:99:99: Ageout AP 172.16.212.89-18:64:72:69:4f:3b-AP105-100 handle_sapcp
    Jul 2 10:04:33 2014 172.16.212.89 stm[1145]: <501080> <NOTI> |AP AP105-100@172.16.212.89 stm| Deauth to sta: 90:b9:31:34:99:99: Ageout AP 172.16.212.89-18:64:72:69:4f:3b-AP105-100 Sapcp Ageout (internal ageout)
    Jul 2 10:04:33 2014 TEST-BE-002 stm[1666]: <501114> <NOTI> <TEST-BE-002 172.16.101.252> Deauth from sta: 90:b9:31:34:99:99: AP 172.16.212.89-18:64:72:69:4f:3b-AP105-100 Reason 255
    Jul 2 10:04:33 2014 TEST-BE-002 stm[1666]: <501044> <NOTI> <TEST-BE-002 172.16.101.252> Station 90:b9:31:34:99:99: No authentication found trying to de-authenticate to BSSID 18:64:72:69:4f:3b on AP AP105-100
    Jul 2 10:06:02 2014 TEST-BE-002 authmgr[1655]: <522038> <INFO> <TEST-BE-002 172.16.101.252> username=xyz MAC=90:b9:31:34:99:99 IP=172.16.103.110 Authentication result=Authentication Successful method=radius-accounting server=TEST-BE-003
    Jul 2 10:09:16 2014 TEST-BE-002 authmgr[1655]: <522005> <INFO> <TEST-BE-002 172.16.101.252> MAC=90:b9:31:34:99:99 IP=172.16.103.110 User entry deleted: reason=user request
    Jul 2 10:09:16 2014 TEST-BE-002 mdns[1788]: <527004> <INFO> <TEST-BE-002 172.16.101.252> mdns_parse_auth_useridle_message 195 Auth User Idle Timeout: MAC:90:b9:31:34:99:99, WIRED:0, FW:0, VLAN:102, IP:172.16.103.110, BSSID:18:64:72:69:4f:3b, AGE:9852,
    -> here we see the role has changed
    Jul 2 10:09:16 2014 TEST-BE-002 authmgr[1655]: <522050> <INFO> <TEST-BE-002 172.16.101.252> MAC=90:b9:31:34:99:99,IP=N/A User data downloaded to datapath, new Role=test-hq-guests-logon/70, bw Contract=0/0, reason=Station resetting role, idle-timeout=300
    So from above i'm seeing the role change due to a user request, which is here probably the same as an idle timeout?  So the age is 9852 which is 164 minutes.  From above i'm learning that every 300 seconds there is a reauthentication.  I'm however not clear why the reauthentication stops at 10:09.  I see last successfull authentication was at 10:06:02.  At 10:09:16 no 300 seconds have passed...  Meaning... it's not a timeout.  What is "reason=user request".  The endpoint device itself which gave up?  It's an iphone btw.  Which i haven't touched since i authenticated this morning...
  • 7.  RE: need to authenticate again after about 40 minutes
    Posted Jul 02, 2014 08:21 AM
    Is this a captive portal network?
  • 8.  RE: need to authenticate again after about 40 minutes
    Posted Jul 02, 2014 09:44 AM
    yes, it is.
  • 9.  RE: need to authenticate again after about 40 minutes
    Posted Jul 02, 2014 09:47 AM
    If the user has no activity for 300 seconds, they will be required to login again. There is a captive portal idle timeout on the AAA profile that can extend this.
  • 10.  RE: need to authenticate again after about 40 minutes
    Posted Dec 14, 2015 07:13 PM
    This response was posted accidentally. Please disregard!
