Hello ,
Use the below VB Script it will help you .You can edit this script as per your requirement .This is an example it will open a command prompt, telnet into an HP Procurve switch and copy its runnung config to a TFTP server.
--------Start Of Script--------
Option Explicit
On Error Resume Next
Dim WshShell, strIP, strTFTP, strFile, strPassHP
Dim filesys, filetxt
strFile = "File Name"
strTFTP = "Your TFTP Server Address"
strPassHP = "Your HP Procurve Password"
'Opens IP address file for reading
Const ForReading = 1, ForWriting = 2, ForAppending = 8
Set filesys = CreateObject("Scripting.FileSystemObject")
Set filetxt = filesys.OpenTextFile(strFile, ForReading, True)
'Opens the command prompt
set WshShell = CreateObject("WScript.Shell")
WshShell.run "cmd.exe"
WScript.Sleep 1000
Do While Not filetxt.AtEndOfStream
strIP = filetxt.ReadLine
Copy(strIP)Loop
filetxt.Close
set WshShell = Nothing
set filesys = Nothing
WScript.Quit
Function Copy(strIP)
WshShell.SendKeys "telnet "& strIP
WshShell.SendKeys ("{Enter}")
WScript.Sleep 1000
WshShell.SendKeys "p"
WshShell.SendKeys strPassHP
WshShell.SendKeys "copy running-config tftp " & strTFTP & " " & strIP & ".txt"
WshShell.SendKeys "^z"
WshShell.SendKeys "y"
WScript.Sleep 2000
End Function
Note :In order for this script to work, you will need a text file will the IP addresses of your switches on a seperate line. You will also need to edit the lines that I have maked in Bold
Thanks and regards
Anurag Thottathil
