Need to reset 3200MX to factory default
  • 1.  Need to reset 3200MX to factory default
    Posted Jul 25, 2012 07:10 PM
    Sirs, I am setting a 3200 Controller up for it was partially and incorrectly setup. I am unable to access the WEB GUI and need to reset this to factory default to completely restart the process. Any assistance with this procedure will be appreciated. Thank you.
    #3200
  • 2.  RE: Need to reset 3200MX to factory default
    Posted Jul 25, 2012 07:21 PM
    Did you try to access via the console?
    "write erase" will do it.
  • 3.  RE: Need to reset 3200MX to factory default
    Posted Jul 25, 2012 07:28 PM
    Thank you.
