Need updated and stable software
  • 1.  Need updated and stable software
    Posted Aug 08, 2020 08:33 AM
    Could you tell recommended software for AP-215 . I am seeing in  Aruba support center its 8.5.0.8 and latest is 8.5.0.10. Which one is recommended and stable version.
    Kanhu
  • 2.  RE: Need updated and stable software
    MVP GURU
    Posted Aug 08, 2020 09:09 AM
    AFAIK all released Aruba software has passed regression tests and if it is published it's considered stable...so you should good to go with 8.5.0.10 with respect to 8.5.0.8 (here the Aruba Instant 8.5.0.10 Release Notes for Centaurus - Aruba AP210 Series Campus Access Points).
  • 3.  RE: Need updated and stable software
    Posted Aug 08, 2020 09:20 AM
    Thank you for quick response,
    Could you update on which url we should refer for finding latest and recommended version for Aruba APs.
    I used to refer Aruba Support Center, any other url we need to refer , please guide.
    Kanhu
  • 4.  RE: Need updated and stable software
    MVP GURU
    Posted Aug 08, 2020 12:22 PM
    A good starting point would be for sure: https://asp.arubanetworks.com -> Software & Documents -> Access Points (AP & IAP).
