Need Windows 10 Driver for USB to UART Cable (Aruba 7005 WLAN Controller)
This thread has been viewed 198 times
  • 1.  Need Windows 10 Driver for USB to UART Cable (Aruba 7005 WLAN Controller)
    Posted Jun 10, 2020 06:39 AM
    i need Windows 10 Driver for USB to UART Bridge Controller Cable for a Aruba 7005 WLAN Controller.
    The Hardware ID is: USB\VID_2626&PID_EA60
    Windows 10 can´t find one.
    The old Aruba Driver ist only for Windows 7: (https://support.arubanetworks.com/ToolsResources/tabid/76/DMXModule/514/EntryId/4229/Default.aspx)
    The Driver for AP UART do not help:
    (https://support.arubanetworks.com/ToolsResources/tabid/76/DMXModule/514/Default.aspx?EntryId=33499)
    regards
    Carsten
  • 2.  RE: Need Windows 10 Driver for USB to UART Cable (Aruba 7005 WLAN Controller)
    Posted Jun 10, 2020 06:44 AM
    For which console port?
  • 3.  RE: Need Windows 10 Driver for USB to UART Cable (Aruba 7005 WLAN Controller)
    Posted Jun 10, 2020 06:48 AM
    For the mini USB Console Port.
  • 4.  RE: Need Windows 10 Driver for USB to UART Cable (Aruba 7005 WLAN Controller)
    Posted Jun 10, 2020 06:58 AM
  • 5.  RE: Need Windows 10 Driver for USB to UART Cable (Aruba 7005 WLAN Controller)
    Posted Jun 10, 2020 07:53 AM
    yes, thats the same driver as from the Aruba Support site:
    (The Driver for AP UART do not help:
    (https://support.arubanetworks.com/ToolsResources/tabid/76/DMXModule/514/Default.aspx?EntryId=33499))
    I can install it, but the device has no driver:
    I have installed and delete the device ans start the PC several times.
    I have try it with manualy updating the driver but windows do not find any drivers in any dezipped folders of this driver.
  • 6.  RE: Need Windows 10 Driver for USB to UART Cable (Aruba 7005 WLAN Controller)
    Posted Jun 10, 2020 08:37 AM
    I had to do some digging to find that cable and when I plugged it in, the driver worked.  Can you try uninstalling and re-installing again?  The Host IDS on my Windows 10 laptop is not allowing me to uninstall to test.
    I am talking about the driver here:  https://support.arubanetworks.com/Default.aspx?TabId=76&DMXModule=514&EntryId=7512
  • 7.  RE: Need Windows 10 Driver for USB to UART Cable (Aruba 7005 WLAN Controller)
    Posted Jun 10, 2020 11:07 AM
    it dosn´t work. The Problem is the Windows 10 error ‘Device not migrated’: https://borncity.com/win/2017/03/15/windows-10-error-device-not-migrated/
    I give up. I will use the normal Console Port.
    Thank you for you support.
  • 8.  RE: Need Windows 10 Driver for USB to UART Cable (Aruba 7005 WLAN Controller)
    Posted Jun 10, 2020 11:09 AM
    Let me ask a co-worker.  I am not sure how I got it to work and I cannot remove it to replicate on my laptop.
    Thanks for your patience.
  • 9.  RE: Need Windows 10 Driver for USB to UART Cable (Aruba 7005 WLAN Controller)
    Posted Jun 11, 2020 03:59 AM
    The 7005 uses the CP210x USB to UART chip, and I just tried on a fresh Windows 10 and was able to make it work with the following steps:
    - Download the CP210x USB to UART Bridge VCP Drivers for Windows 10 from SiLabs.
    - Install the drivers
    - Now go into the Device manager, and search for the Aruba Networks USB to UART Bridge controller under Other Devices
    - Right-click for properties
    - From there click 'Update Driver'
    - Then 'Browse my computer for drivers' (manual select)
    - 'Let me pick from a list of available drivers on my computer
    - Select 'Ports (COM &LPT) from the list of hardware types:
    - Select 'Silicon Labs' from the manufacturers, and Silicon Labs CP210x USB to UART Bridge from the models:
    - Now you will see a warning that Windows cannot verify the compatibility, ignore that:
    - Success message should now appear:
    Screen Shot 2020-06-11 at 09.55.19.pngScreen Shot 2020-06-11 at 09.56.05.png
    Note the COM port number here and open PuTTY or your favorite teminal emulator:
  • 10.  RE: Need Windows 10 Driver for USB to UART Cable (Aruba 7005 WLAN Controller)
    Posted Jun 11, 2020 04:30 AM
    Hello Herman,
    great, thank you. This way works.
    mfg
    Carsten
  • 11.  RE: Need Windows 10 Driver for USB to UART Cable (Aruba 7005 WLAN Controller)
    Posted Dec 15, 2021 09:15 AM
    Also works for the 9004(-LTE) gateway.
    Jan-Willem Keinke
