need your help with 3200 controller
  • 1.  need your help with 3200 controller
    Posted May 24, 2014 01:14 AM
    Dear all,
    i need your help urgent with this case:
    i have a controller 2400 already working fine, when i tried to changed  with the new one controller 3200,
    i used the belwo procedure as follows:(this steps i read it here in this web site)
    1) Backup flash on 2400 and move a copy to a FTP server.
    2) Get IP connectivity to 3200.
    3) Install licenses on 3200 and export the license to a file.
    4) Copy the 2400 flashbackup to the 3200.
    5) Update the ArubaOS on the 3200 to a release equal to the 2400 or higher.
    6) Restore the 2400 flashbackup on the 3200
    7) Restore the backup license file.
    8) Reboot the 3200 and do not save the configuration.
    9) Fix the interfaces on the 3200 controller.
    For now, i can't accessed or ping it , please, how i can access againto the controller and fix this issue
    #3200
  • 2.  RE: need your help with 3200 controller
    Posted May 24, 2014 06:03 AM
    You probably need to login using the console to see what interfaces are there and attempt to "Fix" the uplink interface to the 3200.
  • 3.  RE: need your help with 3200 controller
    Posted Jun 07, 2014 12:10 AM
    thank you , you are right the issue was from the source interface
