Cloud Managed Networks
Negative events on aruba central
This thread has been viewed 22 times
  • 1.  Negative events on aruba central
    Posted May 27, 2024 10:59 AM
    Hello
    im gettnig a lot of this negative events on aruba central
    Onboarding failed for client x in authentication/Association phase BSSID on channel 149 of ap y Reason: Pairwise master key (PMK-R0) Key Holder (R0KH) unreachable
    Does this mean the 802.11r is not working properly? or that the client does not support it or there is an issue with this? or what it could be and how can i fix it
    Carlos
  • 2.  RE: Negative events on aruba central
    Posted May 27, 2024 08:23 PM
    Is this with AOS10 or Instant APs ? and what firmware are you running?
  • 3.  RE: Negative events on aruba central
    Posted May 27, 2024 08:39 PM
    8.11.1.1
    You think its a bug?
    Its managed by aruba central
  • 4.  RE: Negative events on aruba central
    Posted May 27, 2024 09:15 PM
    before that, the latest maintenance for 8.11.x is 8.11.2.2
    There were a few security vulnerabilities that were reported and now fixed in 8.11.2.2, so I suggest to upgrade to that version anyway and see.
  • 5.  RE: Negative events on aruba central
    Posted 11 days ago
    Thank you i upgraded it and it seems that it works fine, after the upgrade i checked with the client a week after and said it was all good for now.  And haven't heard of him in a while so i guess its fixed
    Thanks Ariyap!!!
  • 6.  RE: Negative events on aruba central
    Posted 9 days ago
    glad that it worked out for you.
