Network access control with Aruba ClearPass and Siemens Switch
This thread has been viewed 60 times
  • 1.  Network access control with Aruba ClearPass and Siemens Switch
    Posted Jul 07, 2020 09:24 AM
    As a result of digitization, IT (Information Technology) and OT (Operational Technology) are growing closer and closer together, leading to an increasing number of IT-based systems in OT. These systems are potentially not under the control of IT operations and represent a possible security gap, so the use of network access control systems in OT is becoming increasingly important. Aruba and Siemens formed a strategic partnership to bridge the gap between IT and OT.
    This post is about how the network access of a Siemens Switch (Scalance XC216-4C G, Version 04.01.00) can be controlled with Aruba ClearPass (6.8.0). For this purpose, MAC authentication is used. This means, based on the identity of the end systems maintained in ClearPass, these devices are authenticated on the Switch port. If the authentication is successful, the communication on the Switch port is allowed. If the device is not authorized, no communication is allowed.
    How to use MAC Authentication:
    Add ClearPass as RADIUS server on Switch Interface:
    On Switch Interface go to Security -> AAA -> RADIUS Client -> Create
    Add ClearPass with following information: Auth. Server Type, Server Address, Server Port, Shared Secret
    Configure ports to be used by ClearPass:
    On Switch Interface go to Security -> AAA -> 802.1X Authenticator
    Select Ports, which should be used by ClearPass
    Add Switch in ClearPass:
    In ClearPass go to Configuration -> Network -> Devices -> Add Switch
    With Name, IP Address and Shared Secret
    Create new Enforcement Policy:
    Configuration -> Enforcement Policies -> Add
    Add following parameters:
    Enforcement Type = RADIUS
    Default Profile = Drop Access Profile
    Add 2 rules:
              Authorization failed -> Deny Access Profile
              Authorization successed -> Allow Access Profile
    Create new Service:
    Configuration -> Services -> Add
    Type = MAC Authentication
    Conditions = NAS-Port-Type belongs to Ethernet & Client-MAC-Address equals Radius Username
    Authentication = Method Allow All MAC Auth, Source Endpoints Repository
    Authorization = Endpoints Repository
    Enforcement = Above created Enforcement Policy
    See authorized and unauthorized devices:
    Configuration -> Identity -> Endpoints
    Set Status to Known if a device should be authorized or add new devices
    MAC Authentication with Aruba ClearPass is the basis for various use cases. It is possible to further process the result of the authentication with another enforcement profile which is used in the enforcement policy. For example, the enforcement profile could trigger a lamp with different colors to give a visual representation of the authentication result.
    Addition: MAC Authentication with VLAN assignment:
    VLAN Configuration on Switch Interface:
    On Switch Interface go to Layer 2 -> VLAN
    Assign Uplink Port statically to a VLAN (VLAN10)
    Name = VLAN Enforcement
    Default Profile = Deny Access Profile
    Add rules for VLAN assignment, for example:
              Authorization successed & Description = COTSPD -> VLAN 30 Enforcement
    Exchange this Enforcement Policy with the old one in the Service:
    Configuration -> Service -> Edit Service (Siemens MAC Auth) -> Enforcement Tab
    Select VLAN Enforcement
    Create Enforcement Profiles based on the Actions in the Rule of Enforcement Policy:
    Configuration -> Enforcement -> Profiles -> Add
    Name (VLAN 30 Enforcement)
    Type = RADIUS
    Action = Accept
    Attributes:
              Important to add: Type Radius: Avenda, Name Avenda-Tag-Id, Value 0
    Devices are associated to VLAN based on attributes:
    See in Endpoints Repository (Configuration -> Identity -> Endpoints -> Edit)
  • 2.  RE: Network access control with Aruba ClearPass and Siemens Switch
    Posted Jul 07, 2020 07:35 PM
    Thank you Isabel,
    We're currently in the process {COVID did not help} of validating interoperability between a number of Siemens OT switching lines and ClearPass Policy Manager.
    We've completed our testing here for Scalance and pretty much had completed our testing with Ruggedcom for the 'basic' mac-auth/profile use-cases.
    What we had just started before the lock-down bit us, testing the interop with the Ruggedcom + APE with Nozomi and Fortinet. The COVID unfortunately has stopped that validating in its tracks but once we're back in the office we hope to re-start that project.
  • 3.  RE: Network access control with Aruba ClearPass and Siemens Switch
    Posted Apr 29, 2021 02:04 PM
    Hi! Thank you so much for this helpful information.
    Do you have any idea how you can force the Siemens switch to fallback to a default VLAN once the device disconnects?
    Also when the switch port starts with no vlan config on an interface like explained, it perfectly gets assigned a vlan by Clearpass.. but when I try shortly after that to change it back to another vlan, it stays on the first assigned one?
    Cedric De Witte
  • 4.  RE: Network access control with Aruba ClearPass and Siemens Switch
    Posted Apr 29, 2021 05:34 PM
    Please identify the Siemens switching range in use + s/w version?
    Danny Jump
    "Passionate about CPPM"
  • 5.  RE: Network access control with Aruba ClearPass and Siemens Switch
    Posted Apr 30, 2021 05:47 AM
    Thanks for reply!
    The s/w version is: V04.01.00. Device type is SCALANCE XC216.
    Switch ranges are my vlan's I guess?
    I have 4 VLAN's uplinked on the switch, 2 is Management with Clearpass & switch interface in it, and 3 & 4 are to separate vlan's.
    Ranges are 10.0.<vlanid>.0/24. 3 & 4 both have DHCP from the firewall. (This all works fine when I assign untagged manually)
    The port fa0/2 on which I attached a client doing machine authentication is configured for AAA, also I made this one as 'start configuration' an access port with no untagged vlans configured. On first attempt Clearpass assigned correctly VLAN 3 untagged, but when I change this enforcement policy to assign VLAN 4, the port stays on 3 with an authentication succesfull. So it doesn't change it anymore.
    On Aruba switches, the AAA ports always fallback to the default vlan and port is set every time clearpass configures it after succesfull auth.
    Cedric De Witte
  • 6.  RE: Network access control with Aruba ClearPass and Siemens Switch
    Posted Jun 14, 2021 10:03 AM
    Hi Danny,
    Any idea what the issue could be? I see that the firmware tested is identical?
    The only issue I have is to set the default vlan back once a vlan had been assigned & the device is disconnected.
    Thanks!
    Kind regards,
    Cedric De Witte
  • 7.  RE: Network access control with Aruba ClearPass and Siemens Switch
    Posted Jun 14, 2021 12:59 PM
    Hi Cedric
    I messaged the QA/Test engineer that had been working on the Scalence validation to see if he'd pick up this thread, I know he's been away on paternity leave, I'll ping him again to see if he can chime in with his knowledge.
    Danny Jump
  • 8.  RE: Network access control with Aruba ClearPass and Siemens Switch
    Posted Jun 14, 2021 04:20 PM
    Hi Danny,
    Thank you very much! Really appreciate this.
    Kind regards,
    Cedric De Witte
  • 9.  RE: Network access control with Aruba ClearPass and Siemens Switch
    Posted Oct 06, 2022 05:41 AM
    i am currently trying to get 802.1X (not MAC-Auth) on Siemens XC208G against ClearPass up and running.
    So far the "Guide" provided is very helpfull. I am currently stuck at NOT receiving an "End-Host Identifier" in the Radius request. This is leading to ClearPass not beeing able to properly assign Roles based on the Endpoints repository. I Have checked all information i could get on thte Scalance XC208G Switches but it does not mention anything related.
    ClearPass is on 6.10.7.187596
    Siemens Scalance XC208G is on V04.03.01
    Any help would be highly appreciated
    Martin
  • 10.  RE: Network access control with Aruba ClearPass and Siemens Switch
    Posted Oct 06, 2022 07:29 AM
    Profiling?  What profiling methods are you doing?  What are your Role mappings actually looking for?
  • 11.  RE: Network access control with Aruba ClearPass and Siemens Switch
    Posted Oct 06, 2022 07:50 AM
    thank you very much for the prompt reply.
    In general the Authentication for the same System is working fine with other Type of NADs. Only on the Siemens i do get those issues.
    We do use mainly dhcp for profiling and then we are adding additional information from our CMDB to the Endpoint Database.
    I do see in the Log:
    WARN Common.MacAddrAttrProvider - HostMac missing, not populating different mac representations
    For me this looks like the NAD (Siemens XC208G) is not sending the MAC in the Radius request.
    Martin
