NETWORK OUTAGE
  • 1.  NETWORK OUTAGE
    Posted Dec 20, 2011 02:19 PM
    HELLO
    IN CONFIGURING A VRRP IN PRODUCTION ENVIRONMENT, THE PRIAMRY CONTROLLER IS A 3400 WITH AOS 5 VERSION CODE.
    IN THOS CONTROLLER THE VRRP IP IS 192.,168.170.2 AND ALL THE RAPS ARE UP AND WORKING FINE.
    BUT WHEN I CONNECT THE BACKUP CONTROLLER(3200) TO THE NETWORK ALL THE NETWORK IS DOWN I MEAN VOIP, DATA, PtP LINKS, RAPS ALL IS DOWN.
    WHAT IS THE COMMNAD TO DEBUG THIS PROBLEM, I WANT TO CONNECT THE 3200 AGAIN AND TROUBLESHOOT WHAT IS HAPENING INSIDE THE BOX
    URGENT, THANKS
    #3200
    #3400
  • 2.  RE: NETWORK OUTAGE
    Posted Dec 20, 2011 02:25 PM
    We will need more information.
    Run the following commands on the primary controller and post the output:
    show vrrp
    show ip interface brief
    Then bring up the other controller, without it connected to the network (console into it). Run the same commands and post the output.
    It sounds like you might have a duplicate IP somewhere. Also, are your AP's pointed to the VRRP address as their LMS?
  • 3.  RE: NETWORK OUTAGE
    Posted Dec 20, 2011 02:35 PM
    I DONT HAVE DUPLICATE IP I THOUGHT WAS THAT BUT NO DUPLICATE. :S :S :S
    THIS IS THE MASTER
    (Aruba3400) #show vrrp
    Virtual Router 1:
        Description Preferred-Master
        Admin State UP, VR State MASTER
        IP Address 192.168.170.2, MAC Address 00:00:5e:00:01:01, vlan 170
        Priority 120, Advertisement 1 sec, Preemption Disable
        Auth type PASSWORD, Auth data: 1234567890
        tracking type is master-up-time, duration 30 minutes, value 20
        tracked priority 140
    (Aruba3400) #show ip interface br
    Interface                   IP Address / IP Netmask        Admin   Protocol
    vlan 1                    172.16.0.254 / 255.255.255.0     up      down
    vlan 170                 192.168.170.1 / 255.255.255.0     up      up
    vlan 100                    unassigned / unassigned        up      up
    vlan 101                    unassigned / unassigned        up      up
    vlan 10                     unassigned / unassigned        up      up
    vlan 20                     unassigned / unassigned        up      up
    vlan 30                     unassigned / unassigned        up      up
    vlan 40                     unassigned / unassigned        up      up
    vlan 50                     unassigned / unassigned        up      up
    vlan 60                     unassigned / unassigned        up      up
    vlan 70                     unassigned / unassigned        up      up
    vlan 80                     unassigned / unassigned        up      up
    vlan 90                     unassigned / unassigned        up      up
    vlan 110                    unassigned / unassigned        up      up
    vlan 150                 192.168.150.1 / 255.255.255.0     up      up
    loopback                192.168.170.10 / 255.255.255.255   up      up
    mgmt                        unassigned / unassigned        down    down
    THIS IS THE BACKUP
    (Aruba3200-US) #show vrrp
    (Aruba3200-US) #
    (Aruba3200-US) #show ip interface br
    vlan 1                    172.16.0.253 / 255.255.255.0     up      up
    vlan 170               192.168.170.110 / 255.255.255.0     up      down
    vlan 10                     unassigned / unassigned        up      down
    vlan 20                     unassigned / unassigned        up      down
    vlan 30                     unassigned / unassigned        up      down
    vlan 40                     unassigned / unassigned        up      down
    vlan 50                     unassigned / unassigned        up      down
    vlan 60                     unassigned / unassigned        up      down
    vlan 70                     unassigned / unassigned        up      down
    vlan 80                     unassigned / unassigned        up      down
    vlan 90                     unassigned / unassigned        up      down
    vlan 100                    unassigned / unassigned        up      down
    vlan 110                    unassigned / unassigned        up      down
    vlan 150               192.168.150.110 / 255.255.255.0     up      down
    vlan 101                    unassigned / unassigned        up      down
    loopback                192.168.170.11 / 255.255.255.255   up      up
  • 4.  RE: NETWORK OUTAGE
    Posted Dec 20, 2011 02:46 PM
    How about a show vrrp from the 3200?
  • 5.  RE: NETWORK OUTAGE
    Posted Dec 20, 2011 02:55 PM
    i dont have the vrrp configured yet in the 3200
    THIS IS THE BACKUP
    (Aruba3200-US) #
    :s :S
  • 6.  RE: NETWORK OUTAGE
    Posted Dec 20, 2011 03:01 PM
    Huh. So VRRP isn't configured on the 3200 yet? If you do a show run | begin vrrp, you should see this on the 3200:
    vrrp 1
    authentication password
    ip address 192.168.170.2
    vlan 170
    no shutdown
    Is that in the show run on the 3200?
  • 7.  RE: NETWORK OUTAGE
    To be safe, you should open a support case so that they can troubleshoot this live.  There are a number of factors that could be at play and you cannot afford an outage based on the limited information in the forum.
  • 8.  RE: NETWORK OUTAGE
    Posted Dec 20, 2011 03:04 PM
    Agreed.
  • 9.  RE: NETWORK OUTAGE
    I want ot mention two things first before we set up the VRRP on the backup
    • When you add the backup , make sure that there is no spanning tree issue, check for any loops in the network. On Aruba controllers spanning tree is enabled by default.
    • When you are taking about RAPs, they connect over the internet. So your LMS ip should be a public interface and then your external firewall can nat this IP to the VRRP instance between the master and the backup controller.
    • Configure VRRP on the backup controller with the lower priority than the master else the backup wil become the master and the  database will sync from backup to master
    Sathya
  • 10.  RE: NETWORK OUTAGE
    Posted Dec 20, 2011 03:30 PM
    i agree with all the opinios i opened a case in Aruba but take to long to answer, as you reques the sh run | begin vrrp thi is the ouput
    (Aruba3200-US) #show running-config | begin vrrp
    Building Configuration...
    (Aruba3200-US) #
    I will explain more and sorry for my english but i will write as best i can, ok? I ATTACHED AND IMAGE  of the phisical configuration.
    The network are working fine with only one controller the 3400, i create a VRRP instances in this controller :
    vrrp 1
      priority 120
      authentication c0L1M4n&
      description "Preferred-Master"
      vlan 170
      tracking master-up-time 30 add 20
      no shutdown
    The firewall fortinet it faces to the internet and this dude is made the NAT form the public ip to the interla IP of the VRRP IP 192.168.170.2, from here everithink is ok
    This Aruba3400 is in trunk in the interface GigE:
    interface gigabitethernet  1/0
        description "GE1/0"
        trusted
        trusted vlan 1-4094
        switchport mode trunk
        switchport trunk allowed vlan 10,20,30,40,50,60,70,80,90,100-101,110,150,170
    This port is connected in trunk with the Cisco Siwtch SGE2000, and this swithc is in trunk in other port facing the fortinet, in the fortinet the customer create the sub interfaces. Each VLAN belong to each branch office we connect in the branch an RAP5WN from here all the network is working great!!! the customer is not using autentication all the ports of the RAP are trusted, authenticated allowall and tunnel mode
    in the 3200 i create the same vlans number as the 3400 with no duplicate IP, only 2 VLANS have  IP address the VLAN 170 for the VRRP and the VLAN 150 for the DHCP for the wireless users in case of the primary 3400 fails
    3200
        description "GE1/0"
        trusted
        trusted vlan 1-4094
    The connection betwenn cisco switches are in trunks with the sames VLANS i mentioned in this post......
    A Im clear wtih my writing?
  • 11.  RE: NETWORK OUTAGE
    Posted Dec 20, 2011 03:33 PM
    Sathya no VRRP instances is configured in the backup conttoller im plannign to configure it but i cant because when i plug the patch cord on the port everothing comes down
  • 12.  RE: NETWORK OUTAGE
    Posted Dec 20, 2011 02:38 PM
    yes VRRP as their LMS
