last person joined: 3 hours ago
Network Security Alert Popup
  • 1.  Network Security Alert Popup
    Posted Feb 23, 2018 12:09 PM
    Aruba Instant 305 Cluster - v6.5.3.3
    Cluster has been up and running for several months with no issues.  All of a sudden some people are getting this error (attached) on their screen.  We are authenticating with Clearpass as our RADIUS server.  The client will need to hit connect to connect to our production SSID
  • 2.  RE: Network Security Alert Popup
    Posted Feb 23, 2018 12:14 PM
    Did you change your EAP server certificate?
