Network Management
Network, servers and endpoint monitoring solution?
  • 1.  Network, servers and endpoint monitoring solution?
    Posted Dec 11, 2018 07:50 AM
    Whats the solution Aruba has for network devices monitoring(Switches, APs Etc) , Servers monitoring and end point(IP Cameras, IP phones etc)  monitoring?
    Partner is looking for single minitoring solution for all?
    If its IMC then pls advise on making the BoQ ffor IMC.
    there are 100 devices including all( network devices , Servers monitoring and end points.).
    Thanks in advance.
  • 2.  RE: Network, servers and endpoint monitoring solution?
    MVP GURU
    Posted Dec 11, 2018 08:00 AM
    I would suggest Aruba AirWave but if you need also Server (DC) monitoring - other than Switching Wired and Wireless - maybe the HPE IMC is more appropriate (it's modular)...it depends on your infrastructure.
  • 3.  RE: Network, servers and endpoint monitoring solution?
    Posted Dec 11, 2018 08:58 AM
    so please let me know what more information is required to make the BoQ.
    Currently information we have is that there are 100 devices.
    lets consider out of 100 devices:
    5 are servers
    5 are switches (1 core and 4 Access)
    29 are APs
    1 Wlreless controller
    and 60 are end points like ip phones, ip cameras, latops etc.
  • 4.  RE: Network, servers and endpoint monitoring solution?
    Posted Dec 11, 2018 01:23 PM
    In AirWave - licensing is based on network infrastructure device count.  So licensing would be based on APs, Controllers, Switches, Routers.  The client devices (laptops, cell phones, etc) would just contribute to load - no separate licensing needed.
  • 5.  RE: Network, servers and endpoint monitoring solution?
    Posted Dec 12, 2018 01:41 AM
    yes, I agree with you. Licensing in Airwave is quiet easy.
    No of lic= No of network devices.
    What about IMC?. Can any body share the licensing guide of IMC.?
    How to make BoQ for IMC in above described scenario.
