Network Switch for Voice over Wi-Fi setup
  • 1.  Network Switch for Voice over Wi-Fi setup
    Posted Aug 09, 2012 05:03 AM
    We are doing a Voice over Wi-Fi setup in our office, using IAP-105.
    The Voice over Wi-Fi would communicate with the IP-PBX, in the end via a Network Switch.
    So should we look for a Switch which handles Voice better (I am not sure if there is one!)? Or just any (Gigabit) Switch would be fine?
    Regards
    Yagyesh
  • 2.  RE: Network Switch for Voice over Wi-Fi setup
    Posted Aug 09, 2012 07:37 AM
    Given that you're already with Aruba on wifi side, I would conisder staying with Aruba on wired side. You will realize lots of future upside and integration potential.  Good luck.
    http://www.arubanetworks.com/products/mobility-access-switches/
  • 3.  RE: Network Switch for Voice over Wi-Fi setup
    Posted Aug 09, 2012 10:13 AM
    Good point I'd say...I am checking on the price. I am considering HP 5120 switches as they come with lifetime warranty and are cheaper than Cisco and other big players.
  • 4.  RE: Network Switch for Voice over Wi-Fi setup
    Posted Aug 09, 2012 07:39 AM
    in principle any newish switch would be fine, when you are working with ipt on a LAN then usually there shouldn't be anything limiting the setup, or you must be talking about many many users.
  • 5.  RE: Network Switch for Voice over Wi-Fi setup
    Posted Aug 09, 2012 10:14 AM
    No, the users are only about 35 in number. And there are 4 WAPs.
