New AP-105 does not accept static IP setting (setenv ipaddr)
  • 1.  New AP-105 does not accept static IP setting (setenv ipaddr)
    Posted May 16, 2012 09:02 PM
    Today I opened the new AP-105 box which was shipped 2 weeks ago. If firmware is loaded, it must be matching to the OS 6.1 code.
    I experienced static IP setting (setenv ipaddr) was not accepted by new AP.
    After the AP picked up DHCP IP, default gateway and connected to master controller (resolved host name aruba-master),
    code upgrade (I think downgrade) occured. After the code downgrade, the AP is now capable for static IP setting.
    APBoot 1.2.4.4 (build 26618)
    Built: 2011-01-07 at 13:42:04
    Model: AP-10x
    CPU:   AR7161 revision: A2
    Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
    DRAM:  . 128 MB
    POST1: mem 0 mem 1 mem 2 mem 3 passed
    Copy:  ....    done
    Flash: 16 MB
    PCI:   scanning bus 0 ...
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00  00  168c  0029 00002   01 10000000 00000000 00000000 00000000
           01  00  168c  0029 00002   01 10010000 00000000 00000000 00000000
    Net:   eth0
    Radio: ar922x#0, ar922x#1
    Hit <Enter> to stop autoboot:  2  0  ======> I set static IP address here
    apboot> setenv delayboot 5
    apboot> setenv ipaddr 172.200.250.11
    apboot> setenv netmask 255.255.255.0
    apboot> setenv gatewayo ip 172.200.250.1
    apboot> setenv master 172.200.10  1.208
    apboot> setenv servername aruba-master-sidc
    apboot> save
    Saving Environment to Flash...
    Un-Protected 1 sectors
    .done
    Erased 1 sectors
    Writing
    apboot> printenv
    bootdelay=2
    baudrate=9600
    autoload=n
    boardname=Talisker
    bootcmd=boot ap
    autostart=yes
    bootfile=mips32.ari
    ethaddr=d8:c7:c8:ce:3c:30
    stdin=serial
    stdout=serial
    stderr=serial
    ethact=eth0
    delayboot=5
    ipaddr=172.200.250.11
    netmask=255.255.255.0
    gatewayip=172.200.250.1
    master=172.200.1.208
    servername=aruba-master-sidc
    Environment size: 312/65532 bytes
    apboot> reset
    Model: AP-10x
    DRAM:  . 128 MB
    Copy:  ....    done
    Flash: 16 MB
    Net:   eth0
    Hit <Enter> to stop autoboot:  2  1  0
    Checking image @ 0xbf100000
    Image is signed; verifying checksum... failed! 0xc0890e85
    Checking image @ 0xbf800000
    Invalid image format version: 0xffffffff
    eth0 up: 100 Mb/s full duplex
    ADP multicast 1
    ADP broadcast 1
    ADP multicast 2
    ADP broadcast 2
    ADP multicast 3
    Retry count exceeded
    ADP broadcast 3
    ADP multicast 4
    ADP broadcast 4
    ADP multicast 5
    ADP broadcast 5
    ADP multicast 6
    ADP broadcast 6
    ADP multicast 7
    ADP broadcast 7
    ADP multicast 8   ======> But static IP did not work.
    I purged saved reset, then AP picked up DHCP ip address, then rebooted itself to upgrade the code.
    apboot> purge
    .done
    Erased 1 sectors
    Writing
    apboot> save
    .done
    Erased 1 sectors
    Writing
    apboot> reset
    Model: AP-10x
    DRAM:  . 128 MB
    Copy:  ....    done
    Flash: 16 MB
    Net:   eth0
    DHCP broadcast 1
    DHCP IP address: 172.200.250.103
    DHCP subnet mask: 255.255.255.0
    DHCP def gateway: 172.200.250.1
    DHCP DNS server: 172.200.201.20
    DHCP DNS domain: test.local
    ADP multicast 1
    ADP broadcast 1
    ADP multicast 2
    ADP broadcast 2
    ADP multicast 3
    DNS request 1 for aruba-master.test.local to 172.200.201.20
    T Using eth0 device
    TFTP from server 172.200.1.208; our IP address is 172.200.250.103; sending through gateway 172.200.250.1
    Filename 'mips32.ari'.
    Load address: 0x2000000
    Loading: *################T ###T #################T ################
    done
    Bytes transferred = 3391196 (33bedc hex)
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    Automatic boot of image at addr 0x02000000 ...
    ELF file is 32 bit
    Loading .text @ 0x80e00000 (3322328 bytes)
    Clearing .bss @ 0x8112b1e0 (16 bytes)
    Loading .data @ 0x8112b1f0 (32 bytes)
    ## Starting application at 0x80e00000 ...
    Uncompressing..............................
    Aruba Networks
    ArubaOS Version 5.0.4.6 (build 33270 / label #33270)
    Built by p4build@corsica on 2012-04-13 at 06:47:14 PDT (gcc version 3.4.3)
    CPU Rev: aa
    71x CPU
    Flash variant: default
    Cache parity protection disabled
    Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
    Memory: 123392k/131072k available (1640k kernel code, 7540k reserved, 720k data, 2600k init, 0k highmem)
     available.
    detected lzma initramfs
    initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=13807616
    LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ...................................................................................................................................................................................................................
    AR7100 GPIOC major 0
    wdt: registered with refresh
    Enabling Watchdog
    Talisker RSSI LED initialization
    Creating 1 MTD partitions on "ar7100-nor0":
    0x00000000-0x01000000 : "flash"
    i2c /dev entries driver
    i2c-talisker: using default base 0x18040000
    AD7416 driver probing for devices on AR7100 I2C
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Domain Name: aru banetworks.com
    No panic info available
    Testing TPM... Passed
    <4>ag7100_mod: module license 'unspecified' taints kernel.
    AG7100: Length per segment 512
    AG7100: Max segments per packet 4
    AG7100: Max tx descriptor count    400
    AG7100: Max rx descriptor count    252
    AG7100: fifo cfg 3 018001ff
    AG7100CHH: Mac address for unit 0
    AG7100CHH: d8:c7:c8:ce:3c:30
    ATHRF1: Port 0, Neg Success
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 0
    AP xml model 39, num_radios 2 (jiffies 3467)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 8
    radio 1: band 0 ant 0 max_ssid 8
    asap_gre_init: ADDED GRE protocol c00a5d60
    setting bond0 as bridge child
    setting gre0 as split child
    USB not provisioned
    Starting watchdog process...
    Getting an IP address...
    ag7100_ring_alloc Allocated 4800 at 0x80592000
    ag7100_ring_alloc Allocated 3024 at 0x8079f000
    AG7100: cfg1 0xf cfg2 0x7014
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 3100
    AG7100: unit 0: phy not up carrier 1
    Writing 4
    Kernel watchdog refresh ended.
    AG7100: unit 0 phy is up...RGMii 100Mbps full duplex
    AG7100: pll reg 0x18050010: 0x1099  AG7100: cfg_1: 0x1ff0000
    AG7100: cfg_2: 0x3ff
    AG7100: cfg_3: 0x18001ff
    AG7100: cfg_4: 0xffff
    AG7100: cfg_5: 0x7ffef
    AG7100: done cfg2 0x7115 ifctl 0x10000 miictrl 0x12
    172.200.250.103 255.255.255.0 172.200.250.1
    Running ADP...Done. Master is 172.200.1.208
    ath_hal: 0.9.17.1 (AR5416, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
    ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
    ath_rate_atheros: Aruba Networks Rate Control Algorithm
    ath_dfs: Version 2.0.0
    Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
    ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
    ath_pci: 0.9.4.5 (Atheros/multi-bss)
    wifi0: Base BSSID d8:c7:c8:63:c3:08, 8 available BSSID(s)
    edev->dev_addr=d8:c7:c8:ce:3c:30
    wifi0: AP type AP-105, radio 0, max_bssids 8
    wifi0: Atheros 9280: mem=0x10010000, irq=49 hw_base=0xb0010000
    wifi1: Base BSSID d8:c7:c8:63:c3:00, 8 available BSSID(s)
    wifi1: AP type AP-105, radio 1, max_bssids 8
    wifi1: Atheros 9280: mem=0x10000000, irq=48 hw_base=0xb0000000
    shutting down watchdog process (nanny will restart it)...
     <<<<<       Welcome to the Access Point     >>>>>
  • 2.  RE: New AP-105 does not accept static IP setting (setenv ipaddr)
    Posted May 16, 2012 09:09 PM
    (Continued from the previous post)
    Then AP rebooted to upgrade (downgrade) the code.
    OS of the controller is 5.0.4.6
    ~ # The system is going down NOW !!
    Sending SIGTERM to all processes.
    Please stand by while rebooting the system.
    Restarting system.
    Model: AP-10x
    DRAM:  . 128 MB
    Copy:  ....    done
    Flash: 16 MB
    Net:   eth0
    Signer Cert OK
    Policy Cert OK
    ELF file is 32 bit
    Aruba Networks
    CPU Rev: aa
    71x CPU
     available.
    Enabling Watchdog
    USB not provisioned
    Writing 4
    AP rebooted Wed May 16 14:32:10 EST 2012: SAPD: Reboot after image upgrade   ====> It says reboot after image upgrade.
    After this, I can set static IP (setenv ipaddr).
    I am not sure if latest AP code does not allow static IP setting ...
    Also, I have found that bootdelay (default 2 seconds) can be changed , and servername (host name of the master controller) can be changed by setenv. Is this right things to do?
  • 3.  RE: New AP-105 does not accept static IP setting (setenv ipaddr)
    Posted May 16, 2012 11:23 PM
    Purge and then save wipes everything out.
    What are you trying to accomplish?  Boot the access point to the controller and set the static ip address in Configuration> Wireless> AP Installation.
    Static ip parameters, believe it or not, were not meant to be set on the console.
  • 4.  RE: New AP-105 does not accept static IP setting (setenv ipaddr)
    Posted May 17, 2012 12:21 AM
    Hi cjoseph,
    Yes, we can set static ip address / netmask / default gateway in AP Installation - Provision.
    Our final goal is to send pre-configured AP-105 to branch offices.
    Do you think - assigning static IP address through serial console is informal?
    When I read Aruba documents, they always say that for initial AP deployment, IP should be obtained by DHCP then set static ip from Provision.
    But I know other document (Old Polycom setup manual for Aruba) introduces setting static IP using serial interface.
  • 5.  RE: New AP-105 does not accept static IP setting (setenv ipaddr)
    Posted May 17, 2012 12:23 AM
    Do you need static ip addresses for APs?  Is there No DHCP at those offices?
  • 6.  RE: New AP-105 does not accept static IP setting (setenv ipaddr)
    Posted May 17, 2012 12:43 AM
    Hi cjoseph,
    What we are planning here is remote branch office deployment.
    The reason why we need static ip is because we can manage APs easily by IP addresses.
    We set static IP addresses and AP names , etc on each AP, then send them to remote branch offices for installation.
  • 7.  RE: New AP-105 does not accept static IP setting (setenv ipaddr)
    Posted May 17, 2012 01:32 AM
    The controller keeps a record of each ip address that an access points has, so you don't have to.  Trying to manage the ip address of each AP statically is alot of administrative overhead.
    Just configure a discovery method, use DHCP and the controller will take care of the rest
  • 8.  RE: New AP-105 does not accept static IP setting (setenv ipaddr)
    Posted May 25, 2015 03:53 PM
    Could really use an answer for this???I need to assign static ip addresses to AP-105 for remote office deployment ( 1 per office, no controller)
    Seriously, how the heck would someone thing using DHCP only would be the way to go? Someone actually believes this is manageable by looking up the dhcp assignment for each location????
    I want to assign the same address, just changing the 3rd octet for each location, duh, and manage them by ip address.
  • 9.  RE: New AP-105 does not accept static IP setting (setenv ipaddr)
    Posted May 25, 2015 04:54 PM
    Stephenlisle,
    The original question was that the AP-105 did not accept static ip address entries.  It should accept those static entries and if it does not, it is a bug and TAC should be contacted.  A follow up question discussed the strategy of using DHCP vs. Static.  Users are well within their rights to use whatever method they feel to accomplish their goals.  There are systems that have thousands of access points that exclusively use DHCP and they function as intended.  The system is designed to support either DHCP or the static approach based on administrator preference.
