New AP-105 Not able to Download Image and Join to IAP-105
  • 1.  New AP-105 Not able to Download Image and Join to IAP-105
    Posted Oct 05, 2013 01:26 PM
    I have an IAP-105 been in use for some time now.  It's the only Ap in my network.  Recently wanted to add an AP-105 to the network but cannot figure out how to do it.  I thought it was an "automatic" setup.  When I connect the AP-105 it finds the IAP-105 via DNS lookup, but fails when it tries to do a TFTP download.
    I don't have any documentation on how to do this other than the HOWTO videos here and the quick setup uide - all suggesting this should just work.  Perhaps I have the IAP misconfigured?  I noticed in teh IAP-105 config that teh virtual controller IP address is 0.0.0.0, but tha AP address is 10.10.10.31.  What address do I need for the virtual controller?
    Output of AP-105, Config and Summary of the IAP-105 attached:
    AP-105 BOOTUP OUTPUT
    APBoot 1.0.9.12 (build 22797)
    Built: 2009-11-04 at 15:53:54
    Model: AP-10x
    CPU:   AR7161 revision: A2
    Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
    DRAM:  128 MB
    POST1: passed
    Copy:  done
    Flash: 16 MB
    PCI:   scanning bus 0 ...
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00  00  168c  0029 00002   01 10000000 00000000 00000000 00000000
           01  00  168c  0029 00002   01 10010000 00000000 00000000 00000000
    Net:   eth0
    Radio: ar922x#0, ar922x#1
    Hit <Enter> to stop autoboot:  0
    Checking image @ 0xbf100000
    Invalid image format version: 0xffffffff
    eth0 up: 100 Mb/s full duplex
    DHCP broadcast 1
    DHCP broadcast 2
    DHCP broadcast 3
    DHCP broadcast 4
    DHCP broadcast 5
    Retry count exceeded; starting again
    DHCP broadcast 1
    DHCP broadcast 2
    DHCP broadcast 3
    DHCP broadcast 4
    DHCP broadcast 5
    DHCP IP address: 10.10.10.101
    DHCP subnet mask: 255.255.255.0
    DHCP def gateway: 10.10.10.1
    DHCP DNS server: 192.168.62.14
    DHCP DNS domain: absig.local
    ADP multicast 1
    ADP broadcast 1
    ADP multicast 2
    ADP broadcast 2
    ADP multicast 3
    DNS request 1 for aruba-master.absig.local to 192.168.62.14
    T Using eth0 device
    TFTP from server 10.10.10.31; our IP address is 10.10.10.101
    Filename 'mips32.ari'.
    Load address: 0x2000000
    Loading: T T T T T T T T T T
    IAP-105 SHOW CONFIGURATION
    version 6.2.1.0-3.4.0
    virtual-controller-country US
    virtual-controller-key ff1f6d38014d449b3662071d0431e339147d022b1512795d56
    name irv1iap01
    terminal-access
    ntp-server pool.ntp.org
    clock timezone Pacific-Time -08 00
    clock summer-time PDT recurring second sunday march 02:00 first sunday november 02:00
    rf-band all
    allow-new-aps
    allowed-ap 00:0b:86:cf:91:cc
    arm
     wide-bands 5ghz
     min-tx-power 18
     max-tx-power 127
     band-steering-mode balance-bands
     air-time-fairness-mode fair-access
     client-aware
     scanning
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    mgmt-user admin 90685247062cdaefd06db5ba0d4a4a11a27d9261251635b5
    wlan access-rule ThePin
     index 0
     rule any any match any any any permit
    wlan access-rule default_wired_port_profile
     index 1
    wlan access-rule wired-instant
     index 2
     rule 10.10.10.31 255.255.255.255 match tcp 80 80 permit
     rule 10.10.10.31 255.255.255.255 match tcp 4343 4343 permit
     rule any any match udp 67 68 permit
     rule any any match udp 53 53 permit
    wlan access-rule ABSWireless
     index 3
    wlan ssid-profile ThePin
     enable
     index 0
     type guest
     essid ThePin
     wpa-passphrase 9a73e821702e2f549122c8da948eb2177b3c721cf4c7c775
     opmode wpa-psk-tkip,wpa2-psk-aes
     max-authentication-failures 0
     vlan guest
     rf-band all
     captive-portal disable
     dtim-period 1
     inactivity-timeout 1000
     broadcast-filter none
     per-user-bandwidth-limit 768
     dmo-channel-utilization-threshold 90
     local-probe-req-thresh 0
     max-clients-threshold 64
    wlan ssid-profile ABSWireless
     enable
     index 1
     type employee
     essid ABSWireless
     wpa-passphrase a4d655c28c241003cbaa0455d9f6adba7bd5e6682a9f9df4
     vlan 62
     auth-server InternalServer
     rf-band all
     hide-ssid
     dtim-period 1
    enet-vlan 1
    auth-survivability cache-time-out 24
    wlan external-captive-portal
     server localhost
     port 80
     url "/"
     auth-text "Authenticated"
     auto-whitelist-disable
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids classification
    ids
     wireless-containment none
    wired-port-profile wired-instant
     switchport-mode access
     allowed-vlan all
     native-vlan guest
     no shutdown
     access-rule-name wired-instant
     speed auto
     duplex auto
     no poe
     type guest
     no dot1x
    wired-port-profile default_wired_port_profile
     switchport-mode trunk
     allowed-vlan all
     native-vlan 1
     shutdown
     access-rule-name default_wired_port_profile
     speed auto
     duplex full
     no poe
     type employee
     no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
     preemption
     enforce none
     failover-internet-pkt-lost-cnt 10
     failover-internet-pkt-send-freq 30
     failover-vpn-timeout 180
    airgroup
     disable
    airgroupservice airplay
     disable
     description AirPlay
    airgroupservice airprint
     disable
     description AirPrint
    IAP-105 SHOW SUMMARY
    00:0b:86:cf:91:cc# sh summary
    System Location      :
    Domain               :US
    VC IP Addres         :0.0.0.0
    VC VLAN              :0
    VC Mask              :0.0.0.0
    VC Gateway           :0.0.0.0
    Content Filtering    :disable
    Terminal Access      :enable
    Organization         :
    Airwave Address      :0.0.0.0
    Airwave Backup Address:0.0.0.0
    Airwave Shared Key   :
    Airwave Config Via   :DHCP
    Airwave              :Not Set Up
    Athena Server        :
    Athena               :Not Set Up
    Managed Via          :Local
    Syslog Server        :0.0.0.0
    Syslog Level         :warn
    Band                 :all
    Master IP Address   *:10.10.10.31
    IP Address           :10.10.10.31
    Netmask              :255.255.255.0
    Gateway              :10.10.10.1
    NameServer           :192.168.62.14
    Master Key           :ff1f6d38014d449b3662071d0431e339147d022b1512795d56
    Elected Time         :17h:7m:10s
    Mesh                 :enable
    Dynamic Radius Proxy :disable
    NTP Server           :pool.ntp.org
    Configuration Dirty  :disable
    Allow New APs        :enable
    Classification       :disable
    Wireless Containment :disable
    Wired Containment    :disable
    Rogue Containment    :disable
    LED Off              :disable
    Image Server State   :success
    Image Server Message :Success
    New Image Version    :
    New Image URL        :
    Factory SSID         :instant
    Image Sync Via       :Master
    Client Alerts        :0
    Active Faults        :0
    Fault History        :0
    Serial Number        :BE0053709
    OpenDNS Status       :Not connected
    TFTP Dump Server     :0.0.0.0
    Extended SSID        :disable
    Inactivity-ap-timeout:60
    VPN Status           :Not Set Up
    Mobility Acccess Switch Integration :disable
    Deny inter user bridging :disable
    Deny local routing  :disable
    Support Connection Status           :Not Connected
    Dynamic CPU Management:auto
    1 Client
    MAC                Name  IP Address      Network      Access Point
    1c:e6:2b:f1:28:94        192.168.62.164  ABSWireless  00:0b:86:cf:91:cc
    2 Networks
    Key          Name         Clients  Status
    ThePin       ThePin       0        Enabled
    ABSWireless  ABSWireless  1        Enabled
    1 Access Point
    MAC                IP Address   Name               Clients  Need Antenna Config
    00:0b:86:cf:91:cc  10.10.10.31  00:0b:86:cf:91:cc  1        No
    RADIUS Servers
    Name            IP Address  Port  Key                                                 Timeout  Retry Count  NAS IP Address  NAS Identifier  RFC3576  Airgroup RFC3576-ONLY  Airgroup RFC3576 port
    InternalServer  127.0.0.1   1616  14ee150e01ce110bc09f854e6ccbed1f796c10e47a933f2c73  5        3        0
    RTLS Servers
    Type       IP Address  Port  Key  Frequency  Include Unassociated Stations
    Aeroscout  0.0.0.0     0                     disable
    Airwave    0.0.0.0     0          0          disable
    1 AP Class
    Name   APs
    Orion  1
    Uplink type         :Ethernet
    Uplink status       :UP
    Manual Blacklist Count :0
    Dyn Blacklist Count :0
    Certificate Installed: :No
    Internal Radius Users:  :0
    Internal Guest Users:  :0
    Info timestamp      :61707
    00:0b:86:cf:91:cc#
    #3600
  • 2.  RE: New AP-105 Not able to Download Image and Join to IAP-105
    Posted Oct 05, 2013 02:30 PM
    Introducing a 2nd IAP to the network will be automatic as long as they are in the same L2 domain (VLAN).
    Introducing a 2nd AP that is not an IAP (your description/overview indicates  AP-105  and not IAP-105)  will not work.
    Are you trying to add an "AP" or "IAP" ?
    JF
  • 3.  RE: New AP-105 Not able to Download Image and Join to IAP-105
    Posted Oct 05, 2013 04:08 PM
    Trying to add an "AP".  I was of teh understanding that I only needed one IAP for my network and the remaining units could all be just AP's.
  • 4.  RE: New AP-105 Not able to Download Image and Join to IAP-105
    Posted Oct 05, 2013 04:36 PM
    IAP-105s can only manage other IAPs.
    The AP-105 is a controller-based model and requires one of our controller platforms such as the 600 / 3000/ 7200 series.
