  • 1.  New AP Group
    Posted Oct 03, 2013 02:27 PM
    I need to create a new AP group. I have already cloned an exisiting group.
    The old-group has 3 ssids configured but I only want the new-group to have 2 of the original 3.
    When I disable the VAP or the ssid for #3 in the new-group, it disables it for the old-group as well.
    I'm sure there is a way to do what I need to do but I'm obviously missing something here.
  • 2.  RE: New AP Group
    Posted Oct 03, 2013 02:30 PM
    Clone the VAP as well.  You should then have a new VAP in the new AP group and you can enable/disable it wihtout affecting the original VAP.
  • 3.  RE: New AP Group
    Posted Oct 03, 2013 02:31 PM
    OR... just remove the VAP from the new AP group.
  • 4.  RE: New AP Group
    Posted Oct 03, 2013 02:33 PM
    That was my first thought but I didnt want to have the delete affect the "cloned" group.
    If I delete the VAP from new-group, it wont delete it from the old-group?
  • 5.  RE: New AP Group
    Posted Oct 03, 2013 02:38 PM
    No, it will not. Deleting the VAP from an AP group only removes it from the AP group.
  • 6.  RE: New AP Group
    Posted Oct 03, 2013 02:44 PM
    Does the delete need to be done from the cli?
    I dont see an option for it in the gui.
    I am running v. 6.2.1.2_38532
  • 7.  RE: New AP Group
    Posted Oct 03, 2013 02:50 PM
    I found it in the GUI.
    Deleted the un-needed VAP from the new-group without affecting the old-group.
    Thanks for your help !
  • 8.  RE: New AP Group
    Do you have a single controller or a master/local environment? You can only delete the VAP from an AP group on the master. The local controller is just an AP termination point, not a configuration point.
    If you are on the master (or the only controller in your network), click on Configuration > AP Group > > Wireless LAN > Virtual AP. You should then be able to click the Delete button beside the relevant VAP.
