New APIN303 is not appearing in AOS 8.6.0.2
  • 1.  New APIN303 is not appearing in AOS 8.6.0.2
    Posted Jul 15, 2020 06:43 AM
    Dear all
     We have controller Aruba7210 with AOS 8.6.0.2, we have installed few APIN303 APs but all are not appearing in controller. I have checked all Aps are getting dhcp and even there are enough licenses. But these APs are not appearing in Controller. I will be very grateful if I 'll get help.
    Thanks & Regards
  • 2.  RE: New APIN303 is not appearing in AOS 8.6.0.2
    Posted Jul 15, 2020 06:48 AM
    On the commandline of the controller, type "show ap database" to see if those access points show up with flags.
  • 3.  RE: New APIN303 is not appearing in AOS 8.6.0.2
    Posted Jul 15, 2020 07:26 AM
    Dear, I have checked and didn't find that Aps in ap database also.
  • 4.  RE: New APIN303 is not appearing in AOS 8.6.0.2
    MVP EXPERT
    Posted Jul 15, 2020 07:34 AM
    Do you have your Master Discovery options set (e.g DHCP 43/60 or aruba-master DNS record), have you also checked Control Plane Security as well has not denied the AP?
  • 5.  RE: New APIN303 is not appearing in AOS 8.6.0.2
    Posted Jul 19, 2020 02:07 AM
    Dear Please have a  look into below configuration in control plane control plane security.jpg
    Secondly APs are getting IPs from HP core switch as DHCP pool is created in core switch.
  • 6.  RE: New APIN303 is not appearing in AOS 8.6.0.2
    Posted Jul 19, 2020 06:53 AM
    What method are you using for APS to discover the controller?
  • 7.  RE: New APIN303 is not appearing in AOS 8.6.0.2
    Posted Jul 23, 2020 03:52 AM
    I just did work around and found the solution. I just connected another new AP303 out of my network and login to AP303 and found all others Aps were appearing also. I converted them Manually to AP mode.
    After that found all APs in controller. I have no idea what was logic behind this. APIN303 APs are Unified APS
