New Arubian -- How to reset 3600 controller?
  • 1.  New Arubian -- How to reset 3600 controller?
    Posted Dec 10, 2014 02:14 PM
    I have just inherited a pair of 3600 controllers that were stashed in a closet.  No one has any idea what the login credentials are.  I've searched and found a CLI command (write erase all) to reset to defaults, but AFAIK, I have to get past the login prompt to run that.  At least one of them appears to have been configured at some point, as the serial console shows a hostname, so I'm guessing default credentials are a no-go.  Is there a bigger hammer?
    Also, I don't know what licenses these may or may not have.  Pardon the cluelessness, but is there a retrieval mechanism by serial number, or are they gone for good?  Not a big deal, they may have only been demo units, or expired (if that's how it works), so I'm not expecting much.  Just hoping to have something to poke at while I wait for my schedled training day.
    Thanks everyone.
    #3600
  • 2.  RE: New Arubian -- How to reset 3600 controller?
    Posted Dec 10, 2014 02:20 PM
    You can console in and reset the password.
    Connect to console
    Logon with username as password
    Password is forgetme!
    Then run the following
    enable
    enable
    config terminal
    mgmt-user admin root
    <new password>
    exit
    exit
  • 3.  RE: New Arubian -- How to reset 3600 controller?
    Posted Dec 10, 2014 02:22 PM
    Also, before running write erase all, get the licenses off (if there are any); or just run write erase (no all).
    show license verbose
    license export <name-of-file>
    TFTP file off of controller.
  • 4.  RE: New Arubian -- How to reset 3600 controller?
    Posted Dec 10, 2014 02:45 PM
    Works like a charm, thanks!
  • 5.  RE: New Arubian -- How to reset 3600 controller?
    Posted Sep 01, 2018 03:27 PM
    Moved to separate topic
