New IAP-215 SSID not broadcasting
  • 1.  New IAP-215 SSID not broadcasting
    Posted Jul 27, 2015 12:33 PM
    I have a new out of the box IAP-215. I have set it up with static IP/Mask/Gateway; saved changes, reset/rebooted the AP, but the default INSTANT SSID won't broadcast. I currently have it connected to PoE and hooked up via console. Why can't i see the SSID?
  • 2.  RE: New IAP-215 SSID not broadcasting
    Posted Jul 27, 2015 12:40 PM
    Did you try it with DHCP first?
  • 3.  RE: New IAP-215 SSID not broadcasting
    Posted Jul 27, 2015 12:46 PM
    I don't have a DHCP server setup. I was hoping to setup the AP without one. I'm just trying to get the first one setup initially to test out the various settings with our environment
  • 4.  RE: New IAP-215 SSID not broadcasting
    Posted Jul 27, 2015 12:48 PM
    Did you follow the guide here?:  http://www.arubanetworks.com/techdocs/Instant_41_WebHelp/InstantWebHelp.htm#UG_files/ProvIAP/AssigninganIP.htm
    Make sure you did not make any typgraphical errors.
  • 5.  RE: New IAP-215 SSID not broadcasting
    Posted Jul 27, 2015 12:50 PM
    I've tried those specific instructions multiple times now and still no luck
  • 6.  RE: New IAP-215 SSID not broadcasting
    Posted Jul 27, 2015 12:51 PM
    Please post the console output when it is booting up.
  • 7.  RE: New IAP-215 SSID not broadcasting
    Posted Jul 27, 2015 12:53 PM
    Hit <Enter> to stop autoboot:  0
    apboot> setenv ipaddr 192.0.2.0
    apboot> setenv netmask 255.255.255.0
    apboot> setenv gatewayip 192.0.2.2
    apboot> save
    Saving Environment to Flash...
    Un-Protected 1 sectors
    . done
    Erased 1 sectors
    Writing 9....8....7....6....5....4....3....2....1....
    apboot> printenv
    bootdelay=2
    baudrate=9600
    autoload=n
    boardname=Tomatin
    servername=aruba-master
    bootcmd=boot ap
    autostart=yes
    bootfile=e500.ari
    ethaddr=ac:a3:1e:c5:a3:f6
    stdin=serial
    stdout=serial
    stderr=serial
    ethact=eth0
    ipaddr=192.0.2.0
    netmask=255.255.255.0
    gatewayip=192.0.2.2
  • 8.  RE: New IAP-215 SSID not broadcasting
    Posted Jul 27, 2015 12:57 PM
    You have to type "boot" to boot the access point.
  • 9.  RE: New IAP-215 SSID not broadcasting
    Posted Jul 27, 2015 12:59 PM
    APBoot 1.5.3.9 (build 43867)
    Built: 2014-05-21 at 19:31:10
    Model: AP-21x
    CPU:   P1010E, Version: 1.0, (0x80f90010)
    Core:  E500, Version: 5.1, (0x80212151)
    Clock:
           CPU0: 800 MHz
           CCB:  400 MHz
           DDR:  400  MHz (800 MT/s data rate) (Asynchronous)
           LBC:   unknown (LCRR[CLKDIV] = 0x00)
    L1:    D-cache 32KB enabled
           I-cache 32KB enabled
    I2C:   ready
    DRAM:  Configuring DDR for 800 MT/s data rate
    DDR:   256 MB (DDR3, 32-bit, CL=6, ECC off)
    POST1: memory passed
    Flash: 32 MB
    L2:    256 KB enabled
    Power: 802.3af POE
    PCIe1: RC, link up, x1
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00  00  14e4  4360 00002   03 80000004 00000000 00000000 00000000
    PCIe2: RC, link up, x1
           00  00  14e4  4360 00002   03 a0000004 00000000 00000000 00000000
    Net:   eth0
    Radio: bcm43460#0, bcm43460#1
    Checking image @ 0xee000000
    Copying image from 0xee000000
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    [    0.000000] Flash variant: variant0
    [    0.000000]
    [    0.000000] Aruba Networks
    [    0.000000] ArubaOS Version 6.4.2.0-4.1.1.0 (build 45444 / label #45444)
    [    0.000000] Built by p4build@cartman on 2014-08-15 at 22:19:51 PDT (gcc version 4.5.1)
    [    0.000000]
    [    0.000000] P1010 RDB board from Freescale Semiconductor
    [    0.000000] Memory: 246716k/262144k available (12184k kernel code, 15428k reserved, 504k data, 358k bss, 8792k init)
    [    0.001491] Brought up 1 CPUs
    [    0.077633] PCI: Probing PCI hardware
    [    0.120682] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
    [    0.183587] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
    [    0.245812] pci 0000:00:00.0: not setting up bridge for bus 0000:01
    [    0.320382] pci 0001:02:00.0: not setting up bridge for bus 0001:03
    [    6.321896] fsl-ifc ffe1e000.ifc: Freescale Integrated Flash Controller
    [    6.426831] Kprobe smoke test started
    [    6.476759] Kprobe smoke test passed successfully
    [    6.640953] ee000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank
    [    6.716043] Amd/Fujitsu Extended Query Table at 0x0040
    [    6.777536] number of CFI chips: 1
    [    6.821990] fsl-gianfar ethernet.2: enabled errata workarounds, flags: 0x4
    [    6.904382] gfar_probe: Renaming interface to bond0
    [    6.963146] /proc/gfar_bond0_stats created
    [    7.025315] Enabling watchdog on CPU 0
    [    7.074246] Disabled fips elf aesccm selftest
    [    7.126414]
    [    7.126418] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    [    7.218174] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    [    7.308033] Starting Kernel DES KAT ...Completed Kernel DES KAT
    [    7.379981] Starting Kernel AES KAT ...Completed Kernel AES KAT
    [    7.423776]
    [    7.469640] Starting Kernel HMAC SHA1 FIPS KAT ...Completed Kernel HMAC SHA1 FIPS KAT
    [    7.564922] Starting Kernel HMAC SHA256 FIPS KAT ...Completed Kernel HMAC SHA256 FIPS KAT
    [    7.668163] Starting Kernel HMAC SHA384 FIPS KAT ...Completed Kernel HMAC SHA384 FIPS KAT
    [    7.772368] Starting Kernel HMAC SHA512 FIPS KAT ...Completed Kernel HMAC SHA512 FIPS KAT
    [    7.876561] Starting Kernel AES-CBC FIPS KAT ...Completed Kernel AES-CBC FIPS KAT
    [    7.974017] Starting Kernel 3DES-CBC FIPS KAT ...Completed Kernel 3DES-CBC FIPS KAT
    Domain Name: instant.arubanetworks.com
    No panic info available
    Backup ENV.
    Cfg len is 2.5k
    Loading configuration file of length 2.5k...
    wifi uplink not present...
    extended ssid config detected...
    Terminal access enabled...
    factory default SSID detected...
    extended ssid activate due to no valid ssid ...
    Cfg len is 2.5k
    [   14.777420] ADDRCONF(NETDEV_UP): bond0: link is not ready
    Ethernet uplink not active yet
    Mesh is DISABLED on this device.
    [   45.244360] AP xml model 84, num_radios 2 (jiffies 22449)
    [   45.309008] init_asap_mod: installation:0
    [   45.356957] radio 0: band 1 ant 0 max_ssid 16
    [   45.409062] radio 1: band 0 ant 0 max_ssid 16
    [   45.461178] election init: rand=1d HZ=500
    [   45.509121] IAP client match init
    notify asap_mod 3g no present...
    Starting watchdog process...
    Got all network params from APboot env. Skipping DHCP
    Static IP detected. Checking if LACP needs to be configured
    cat: /sys/class/net/bond0/bonding/mode: No such file or directory
    LACP mode set to
    192.0.2.0 255.255.255.0 192.0.2.2
    Compressing all files in the /etc/httpd directory...
    Done.
    Starting Webserver
    bind: Transport endpoint is not connected
    Launching NTP Client on pool.ntp.org
    [  104.716010] wifi0: AP type AP-215, radio 0, max_bssids 16
    [  104.823655] wifi1: AP type AP-215, radio 1, max_bssids 16
    AP rebooted Thu Jan 1 00:06:46 UTC 1970; Current uplink down, no useable uplink
    shutting down watchdog process (nanny will restart it)...
    Completed SW FIPS KAT test
            <<<<<       Welcome to the Access Point     >>>>>
    User:
  • 10.  RE: New IAP-215 SSID not broadcasting
    Posted Jul 27, 2015 01:08 PM
    The access point does not see the physical link.  Is the AP ethernet light lit up?  I would check the cable, etc to make sure it is right:
  • 11.  RE: New IAP-215 SSID not broadcasting
    Posted Jul 27, 2015 01:11 PM
    Must i have an uplink? I'm not looking to have any internet access. The power light is a redish color and the 2.4/5 GHz lights are amber
  • 12.  RE: New IAP-215 SSID not broadcasting
    Posted Jul 27, 2015 01:13 PM
    For the instant SSID to appear you do need an uplink. After that you can configure it to not require an uplink.
  • 13.  RE: New IAP-215 SSID not broadcasting
    Posted Jul 27, 2015 03:48 PM
    Thank you, The uplink was the key to seeing the instant ssid broadcast. What settings do i alter in order to be able to still connect to the AP and then access the https://instant.arubanetworks.com site?
  • 14.  RE: New IAP-215 SSID not broadcasting
    Posted Aug 04, 2015 08:31 AM
    Alternatively, you can use "setenv standalone_mode 1" on the console, to enable standalone mode, which can allow the AP to come up without Ethernet uplink.
