Currently I've got about 30 schools using aruba APs, the large campuses have controllers, the remaining 25 sites are using instant clusters. The campus APs are currentling using DNS (centrally managed) to find aruba-master.
We have older 93H APs used in some places as switches with the radios turned off, these are provisioned to use a central controller for management.
If I try to add a new or replacement IAP to an instant cluster they are now seening the aruba-master DNS entry and converting to campus AP automatically and await provisioning on the master instead of joining the local cluster (running 6.5).
If I delete the aruba-master dns entry, wipe an AP and reboot it joins the cluster properly.
Is this a bug for the APs to convert to campus APs without me having to go into them and choose to convert to campus AP? I'd rather them not do this, if it's a new feature can it be turned off on the IAPs before deploying?
The instant clusters are on 6.5.3.2 (6.4 works as I exprected).
The controllers are on 6.4.4.8.
I appreciate any feedback!
