New outdoor AP compatible with IAP 205 virtual controller setup
  • 1.  New outdoor AP compatible with IAP 205 virtual controller setup
    Posted May 29, 2020 07:24 AM
    we have a wifi-network with 6 IAP-205 and 1 IAP-275. We need to add 1 new outdoor access point to that system. What we can see is that the IAP-275 has gone end of life and the
    AP-375, listed as a replacement, can not go lower than
    Aruba InstantOS 8.3.0.0, so we can not include it in the
    same virtual-controller setup. Does anyone have experience with AP-365? If you check the
    minimum software version it says Unified ArubaOS and Instant 6.5.2.0 and 8.2.0. Does anyone know if it can be downgraded to Instant OS 6.5.2.0 or if it is 8.2.0 that applies to instant?
    If the AP-365 can't be downgraded to 6.5.2.0, does anyone
    know if there is an outdoor ap that can be downgraded to
    Instant 6.5 which seems to be the highest firmware version
    that IAP-205 can be upgraded to.
    Thanks in advance.
    Martin Eriksson
  • 2.  RE: New outdoor AP compatible with IAP 205 virtual controller setup
