This are first setup of this type and I would like a few tips if possible.
Equipment
4 - 175P
4 - Sets of ANT -2005 - H and V omnidirectional antennas
4 - ANT - 2x2 - 5314 antennas
I know where each antenna attaches but I can't seem to find the best practice when attaching these antennas.
For the omnidirection antennas is it best to use both or just one?
And I have a similar question about the 2x2 - 5314 antennas. Should I connect both the horizontal and vertical connections to the 175P?
Also in our lab we have a similar setup for testing except we have ANT-3x3-D608s instead of the 5314 antennas. Will the D608s work with the 175Ps?
Any help would be appreciated. Thanks.
