last person joined: 7 hours ago
New to Aruba - 3 APs and one will not pick up clients
  • 1.  New to Aruba - 3 APs and one will not pick up clients
    Posted Jul 10, 2018 07:17 AM
    I have the following APs and I can't seem to get the 377 to gain any clients when they are directly in front of it, 15 feet away. The clients seem to remain on the 345 AP which is providing weak signal from this location. I must be missing something in the setup of this network.
    377(outdoor) - Yard
    345(indoor) Main Bldg
    305(indoor) Garage Bldg
  • 2.  RE: New to Aruba - 3 APs and one will not pick up clients
    Posted Jul 10, 2018 07:22 AM
    How high is the AP 377 mounted?
    On the commandline of the controller, type "show ap bss-table" to ensure that the AP-377 is indeed broadcasting an SSID.
  • 3.  RE: New to Aruba - 3 APs and one will not pick up clients
    Posted Jul 12, 2018 10:09 AM
    It doesnt appear it is...
    Num APs:0
    Num Associations:0
    Flags: K = 802.11K Enabled; W = 802.11W Enabled;
    WAP Backyard# show ap bss-table
    Aruba AP BSS Table
    bss ess port ip phy type ch/EIRP/max-EIRP cur-cl ap name in-t(s) tot-t flags
  • 4.  RE: New to Aruba - 3 APs and one will not pick up clients
    Posted Jul 12, 2018 01:05 PM
    Do your APs all use the same profiles?
    If not, what are the differences?
    Are all these APs under a single Master controller?
    What version of aos are you running?
  • 5.  RE: New to Aruba - 3 APs and one will not pick up clients
    Posted Jul 12, 2018 02:22 PM
    See picture below of Instant - Virtual Controller. I assume it is in the same profile as it shows in the moddle box down below as an AP in this Network.
    WAP Backyard = ArubaOS (MODEL: 377), Version 8.3.0.0
    WAP Foyer = ArubaOS (MODEL: 345), Version 8.3.0.0
    WAP Garage = ArubaOS (MODEL: 305), Version 8.3.0.0
  • 6.  RE: New to Aruba - 3 APs and one will not pick up clients
    Posted Jul 16, 2018 08:32 AM
    POE incector was not powerfull enough to allow the AP to fire up the radios. Got a new POE injector capable of POE-AT and problem solved.
    Part of being a newbie, I guess.
  • 7.  RE: New to Aruba - 3 APs and one will not pick up clients
    Posted Jul 16, 2018 08:38 AM
    Hi
    From the datasheet:
    POWER • Worst-case power consumption from the AP: 23W • Power sources sold separately • Power over Ethernet (PoE+): 802.3at-compliant • AC Power: 100-240 Volt 50/60Hz AC
    AP-370 need PoE+ always.
  • 8.  RE: New to Aruba - 3 APs and one will not pick up clients
    Posted Jul 10, 2018 05:05 PM
    Does your software version and/or DRT file support the country where the 377 is deployed? It's a relatively new platform, and default FW/DRT may not support it yet.
  • 9.  RE: New to Aruba - 3 APs and one will not pick up clients
    Posted Jul 12, 2018 06:20 PM
    Hi
    Maybe upgrade to 8.3.0.1?
