New to Aruba - Channel width
  • 1.  New to Aruba - Channel width
    Posted Jun 15, 2020 04:20 PM
    We had a wireless assesmment and are getting 8 new Aruba 315's installed this week, replacing the 215s we have now. These are all instant access points.
    Will the new Access points get the configuration from the existing ones, and when we turn off the old APS will one of the new ones become the master (we will be removing the old access points at the end) ?
    Also one of the recommendations was "Suggest turning off 2.4 and adjusting channel width to 20"
    I can not figure out how to adjust the channel width.
  • 2.  RE: New to Aruba - Channel width
    Posted Jun 15, 2020 05:54 PM
    Are these Instant APs or Controller-based?  The answers will differ based on the answer to that question.
  • 3.  RE: New to Aruba - Channel width
    MVP GURU
    Posted Jun 15, 2020 10:38 PM
    See the following screenshots for turning the 5Ghz down to use only 20Mhz channels. IAP and Controller Based.
  • 4.  RE: New to Aruba - Channel width
    Posted Jun 16, 2020 09:55 AM
    I dont seem to have a profile section.
  • 5.  RE: New to Aruba - Channel width
    MVP GURU
    Posted Jun 16, 2020 10:31 AM
    You were probably looking at the controller based config. See the IAP screenshot below or attached.
  • 6.  RE: New to Aruba - Channel width
    MVP GURU
    Posted Jun 16, 2020 10:32 AM
    You will have to click the "show advanced options" button on the bottom to show them.
  • 7.  RE: New to Aruba - Channel width
    Posted Jun 16, 2020 01:16 PM
    I did click on the show advanced. I see the RF section for the 5 GHz, should I also see something for channel width of 20 ?
  • 8.  RE: New to Aruba - Channel width
    MVP GURU
    Posted Jun 16, 2020 01:31 PM
    Turning off wide channel bands should get you down to 20Mhz.
  • 9.  RE: New to Aruba - Channel width
    Posted Jun 16, 2020 09:51 AM
    This is Instant
