New User for IAP-207-RW. Need an Advice.
  • 1.  New User for IAP-207-RW. Need an Advice.
    Posted Apr 03, 2018 09:43 PM
    Have 2 Unit But how to Clustering ?
    My Auto Join Was Enable But how i know which Clustering Group or the AP is in  Clustering Or Not . Using Web UI
    Thanks .
  • 2.  RE: New User for IAP-207-RW. Need an Advice.
    Posted Apr 03, 2018 09:48 PM
    On the WebUI, the center window panel should list the APs that are part of that VC’s cluster. If your other IAP-207 joined the cluster, you’ll see two APs listed there.
  • 3.  RE: New User for IAP-207-RW. Need an Advice.
    Posted Apr 03, 2018 10:22 PM
    Hi cclemmer
    do you means the Access Point will list the clustering AP ?
    Ok .. mine one is not showing.can i know where should i configure the clustering ?
    thanks
  • 4.  RE: New User for IAP-207-RW. Need an Advice.
    MVP EXPERT
    Posted Apr 04, 2018 01:08 AM
    You need to ensure that both of the IAP’s are in the same broadcast domain. Auto election will not occur if the AP’s are not in the same broadcast domain.
  • 5.  RE: New User for IAP-207-RW. Need an Advice.
    Posted Apr 04, 2018 02:57 AM
    same broadcast domain ? are this a setting ?
    i not sure is same broadcast domain or not .
    but i very sure is same ip same gateway and same network
  • 6.  RE: New User for IAP-207-RW. Need an Advice.
    MVP EXPERT
    Posted Apr 04, 2018 03:02 AM
    Are they in the same subnet? Is there any fire walls blocking traffic between the IAP.
    Sent from my iPhone
  • 7.  RE: New User for IAP-207-RW. Need an Advice.
    Posted Apr 04, 2018 03:08 AM
    Yes they are same subnet. nope, there is no fire walls blocking traffic between the IAP.
  • 8.  RE: New User for IAP-207-RW. Need an Advice.
    MVP EXPERT
    Posted Apr 04, 2018 03:17 AM
    Have you performed basic troubleshooting to confirm each IAP can reach each other?
    Sent from my iPhone
  • 9.  RE: New User for IAP-207-RW. Need an Advice.
    Posted Apr 04, 2018 05:00 AM
    Yep yep they can reach each others .
    i just not sure is it something i missing .
    because on HPE AP they got a Location to key for clustering .
    but i not sure is it aruba same
  • 10.  RE: New User for IAP-207-RW. Need an Advice.
    MVP EXPERT
    Posted Apr 04, 2018 05:12 AM
    Hey no key as such for the Aruba IAP. Providing you have auto join enabled and the IAP are in the same broadcast domain they will find each other and automatically elect a Master. Is the trunk ports which the IAP connected on the same configuration?
    Sent from my iPhone
  • 11.  RE: New User for IAP-207-RW. Need an Advice.
    Posted Apr 04, 2018 05:22 AM
    Oh so it is auto . Yep Yep all same .
    Hmm i think i think i just try a factory reset see how is it .
    Thanks for your reply
    *Update*
    i have reset my both AP ... finaly it saw each others on the Access Point Tab..
    i notice both of them having Master IP...should i Configure Vitrual Controller IP ?
  • 12.  RE: New User for IAP-207-RW. Need an Advice.
    MVP EXPERT
    Posted Apr 04, 2018 07:39 AM
    They will both show the Master IP as this means the IAP is aware of who has elected itself as the Master IAP. Each IAP will have a unique IP address. Yes you should configure a VC IP for management purposes.
    Sent from my iPhone
  • 13.  RE: New User for IAP-207-RW. Need an Advice.
    Posted Apr 04, 2018 08:12 PM
    Oh Many thanks . so will be more easy to manage.
    Finaly... i think i try one by one for others feature .
    thanks for all the reply
