BSSID: 6C:C4:9F:C7:D9:81
SSID: RWC-CORP
Annotation:
Vendor:
AP Name: AP-62
AP Model: 515
RSSI: -44 dBm
Noise: -101 dBm
SNR: 57 dB
Signal: 91 %
Frequency: 2412 MHz
Band: 2.4 GHz
Channel: 1
Channel Width: 20 MHz
Country:
Beacon Period: 102.4 ms
Min MCS Rate: 7.2 Mbps
Max MCS Rate: 144.4 Mbps
Basic Rate Set: 6/9
Supported Rates: 6 (B), 9
BSS Type: Infrastructure
Type 802.11: n
WiFi Generation: 4
Amendments: e i r v
Streams: 2
Stations: 0
Channel Utilization: 39 %
Security: WPA2 Enterprise
Group Cipher: AES
Pairwise Cipher: AES
AKM Suite: 802.1X
Min Power:
Max Power:
Mac Age: 1/1/1900 12:00:00 AM
First Seen: 11/14/2022 4:36:13 PM
Last Seen: 11/14/2022 4:37:44 PM
BSSID: 6C:C4:9F:C7:D9:91
SSID: RWC-CORP
Annotation:
Vendor:
AP Name:
AP Model:
RSSI: -56 dBm
Noise: -101 dBm
SNR: 45 dB
Signal: 85 %
Frequency: 5180 MHz
Band: 5 GHz
Channel: 36
Country:
Max MCS Rate: 346.8 Mbps
Basic Rate Set: 12/18
Supported Rates: 12 (B), 18
Type 802.11: ac
WiFi Generation: 5
Amendments: e i r v
Streams: 4
Stations: 3
Channel Utilization: 7 %
Group Cipher: AES
AKM Suite: 802.1X
Min Power:
Max Power:
Last Seen: 11/14/2022 4:39:42 PM
Original Message:
Sent: Nov 14, 2022 04:05 PM
Subject: New Wireless Setup - AP515 and AP514
Can you install https://www.tethabyte.com/download and send a txt export of the results. When see your SSID rightclick to export as txt.
Please note that 173Mbps is the max. modulation when using 20MHz width channels by two spatial streams.
Interesting in a export like this:
BSSID: xx:xx:xx:xx:xx:xx
SSID: HomeLAB-Corp
Annotation:
Vendor: Aruba, a Hewlett Packard Enterprise Company
AP Name:
AP Model:
RSSI: -38 dBm
Noise: -95 dBm
SNR: 57 dB
Signal: 94 %
Frequency: 5520 MHz
Band: 5 GHz
Channel: 104
Channel Width: 80 MHz
Country: NL
Beacon Period: 102,4 ms
Min MCS Rate: 36 Mbps
Max MCS Rate: 1201 Mbps
Basic Rate Set: 24/36/48/54
Supported Rates: 24 (B), 36, 48, 54
Type 802.11: ax
WiFi Generation: 6
Amendments: d e h i r v
Streams: 2
Stations: 6
Channel Utilization: 2 %
Security: WPA2 Personal
Group Cipher: AES
AKM Suite: PSK
Min Power:
Max Power:
Mac Age: 14-5-2019 00:00:00
First Seen: 14-11-2022 22:01:56
Last Seen: 14-11-2022 22:04:09
Marcel Koedijk | MVP Expert 2022 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
Original Message:
Sent: Nov 14, 2022 03:05 PM
Hi
Thank you for replying.
I have now 4 SSIDs.
3 of the 4 were setup originally by the company who setup the VC and all the APs. Those 3 SSIDs i can only seem to get 173mbps data transfer rate.
I then created a new SSID with identical settings to the other 3 and getting 286mbps speeds. I know there is a misconfiguration somewhere, just need to know where exactly.
Original Message:
Sent: Nov 14, 2022 01:59 PM
The more SSIDs you add, the more your performance will decrease. Try to reduce the number of SSIDs so see if your performance improves.
Original Message:
Sent: Nov 10, 2022 01:34 PM
Hello everyone,
I am not sure if anyone has run into this before. Our issue with our new Aruba Wireless Setup is that our through put speeds are slow.
We have good signal strength, but slow speeds. I contacted Aruba support and they said my speeds are good (150mbps)
We cannot get past 173mbps on any of the new APs. I checked another post that talked about LLDP and i have verified in all switches and it is enabled.
Our radio power is at 21dbe and firmware running on 8.7.1.6_81786.
We have a total of 5 SSIDs setup in Aruba Central, does not make a difference which SSID i connect, i still get same speeds.
On legacy devices, such as Zebra VH10 Mobile Computers, our data rate speeds is about 50mbps causing frustration on users.
Is there something i should be looking in Aruba Central's setting to increase my network speeds on my APs?
Abiel Valdez
Abiel Valdez
