New WLAN - Error Invalid: VLAN does not exist
  • 1.  New WLAN - Error Invalid: VLAN does not exist
    Posted Jan 17, 2012 07:02 AM
    I've created a new WLAN and get the VLAN does not exist error message but can't find why I'm getting the error message and I presume is causing the SSID not to be broadcast.
    Below is the the error I'm seeing from the CLI.
    Virtual AP profile List
    Name           References  Profile Status
    default        1
    VAP-DWLAN      3
    VAP-MWLAN      2
    VAP-PWLAN      2
    VAP-WIFISpark  1           Invalid: VLAN 66 does not exist
    Jan 17 09:39:42  stm[1814]: <305004> <ERRS> |stm|  AP PH09_9A_AP3: wlan virtual-ap "VAP-WIFISpark" is invalid.
     ip radius source-interface vlan 7
    controller-ip vlan 7
    interface mgmt
        dhcp
    vlan 7 "NETWORK_MANAGEMENT"
    vlan 66 "WIFISPARK"
    vlan 202 "PWLAN"
    vlan 203 "MWLAN"
    vlan 250 "DATA"
    interface gigabitethernet  0/0
        description "GE0/0"
        trusted
        trusted vlan 1-4094
        switchport mode trunk
        lacp group 0 mode active
    interface gigabitethernet  0/1
        description "GE0/1"
        trusted
        trusted vlan 1-4094
        switchport trunk allowed vlan 7,202-203,250
    interface gigabitethernet  0/2
        description "GE0/2"
        trusted
        trusted vlan 1-4094
    interface gigabitethernet  0/3
        description "GE0/3"
        trusted
        trusted vlan 1-4094
    interface port-channel 0
        trusted
        trusted vlan 1-4094
        switchport trunk allowed vlan 7,66,202-203,250
    interface vlan 7
        ip address 10.170.38.20 255.255.255.0
    interface vlan 1
    interface vlan 250
        ip address 10.170.28.2 255.255.252.0
    interface vlan 202
        ip address 10.170.32.2 255.255.255.0
    interface vlan 66
        ip address 172.30.4.5 255.255.252.0
        ip helper-address 172.30.4.1
        description "WIFISPARK"
    ip default-gateway 10.170.38.1
    uplink disable
    aaa authentication mac "default"
    aaa authentication dot1x "default"
    aaa authentication dot1x "DOT1X-PSK"
    aaa authentication dot1x "DOT1X-RADIUS"
       termination eap-type eap-peap
       termination inner-eap-type eap-mschapv2
    ap system-profile "APSP-PILGRIM"
       lms-ip 10.170.38.20
       bkup-lms-ip 10.169.231.131
       lms-preemption
    wlan ssid-profile "SSID-WIFISpark"
       essid "WIFISPARK"
       aaa-profile "NoAuthAAAProfile"
       vlan 66
    ap-group "APG-PILGRIM"
       ap-system-profile "APSP-PILGRIM"
    Any help would be much appreciated.
    Jon
  • 2.  RE: New WLAN - Error Invalid: VLAN does not exist
    Posted Jan 17, 2012 07:18 AM
    Remove the ip interface for vlan 66
    Remove the VLAN66
    Recreate Vlan 66
    Recreate the ip interface for VLAN66
    See if that works.
  • 3.  RE: New WLAN - Error Invalid: VLAN does not exist
    Posted Jan 17, 2012 10:08 AM
    I've done as you suggested and still get the VLAN does not exist.
    Something else I have tried is changing the VLAN that we use for management and it worked fine the SSID started being broadcast on all our AP's so its something to do with the way VLAN 66 is configured but I can't see anything that's wrong with the config.
  • 4.  RE: New WLAN - Error Invalid: VLAN does not exist
    Posted Jan 17, 2012 10:45 AM
        description "GE0/1"
        trusted
        trusted vlan 1-4094
        description "GE0/2"
        trusted
        trusted vlan 1-4094
        description "GE0/3"
        trusted
        trusted vlan 1-4094
        trusted
        trusted vlan 1-4094
    Take a look at the lines outlined above.  VLAN 66 is not part of the trunk allowed VLANs on the 3 physical ports, although it is allowed on the port-channel.  Add VLAN66 and see if that works.  Also confirmed that VLAN 66 is being trunked from the upstream switch.
    -Mike
  • 5.  RE: New WLAN - Error Invalid: VLAN does not exist
    Posted Jan 18, 2012 07:55 AM
    VLAN 66 is defiantely working up and downstream of the LAN as I can ping both way.
    I did try adding the VLAN to the individual interfaces but it errors saying its in a trunk, the only way to do it would be to remove the interfaces from the trunk and make the change and then re-add.
    I'll try it this afternoon.
  • 6.  RE: New WLAN - Error Invalid: VLAN does not exist
    Posted Jan 18, 2012 07:57 AM
    Try changing to Virtual AP vlan to something else, then back to vlan 66.
  • 7.  RE: New WLAN - Error Invalid: VLAN does not exist
    Posted Jan 18, 2012 08:35 AM
    I've already tried that, changed it to VLAN 7 and it worked fine but switching back to vlan 66 didn't make any difference.
  • 8.  RE: New WLAN - Error Invalid: VLAN does not exist
    Posted Jan 18, 2012 08:45 AM
    Please open a support case, then.
  • 9.  RE: New WLAN - Error Invalid: VLAN does not exist
    Posted Aug 29, 2012 08:49 AM
    Wanted to share my experience with something very similar.
    I had an AP group with 2 VAPs, each VAP had 1 SSID profile with a different VLAN
    the 2nd VAP wouldn't broadcast my SSID. Kept saying "VLAN165 does not exist"
    After reading this thread, I did the following.
    1. Removed interface vlan 165
    2. removed vlan 165
    3. re-created both, did not work.
    4. removed both, created vlan 199, assigned same IP range as vlan 165, WORKED.
    5. removed vlan 199
    6, re-added vlan 165, WORKED.
    Pulling my hair out for this.
    VLAN 165 existed the entire time and "show profile-errors" displayed nothing.
  • 10.  RE: New WLAN - Error Invalid: VLAN does not exist
    Posted Jan 18, 2012 08:34 AM
    I've removed the trunk allowed off all the interfaces and I still get VLAN 66 doesn't exist.
