Newbie-Question: IAP-93 Manuals and Repeater Mode
  • 1.  Newbie-Question: IAP-93 Manuals and Repeater Mode
    Posted Sep 07, 2012 06:05 PM
    Hi there!
    I'm completely new to Aruba and have two questions:
    1) Where do I find manuals about IAP-93? There was no CD in the package and I cannot find it on arubanetworks.com
    2) Is it possible to use the IAP-93 to extend an existing Wifi network? If yes, how?
    Thanks a lot!
    Tademos
  • 2.  RE: Newbie-Question: IAP-93 Manuals and Repeater Mode
    Posted Sep 07, 2012 06:15 PM
    Tademos,
    You can find the documentation related to IAP under the documentation tab on the support website
    http://support.arubanetworks.com/DOCUMENTATION/tabid/77/Default.aspx
    You should find
    1. Installation guide for IAP - 92/93
    2. Quick Start Guide
    3. User Guide
  • 3.  RE: Newbie-Question: IAP-93 Manuals and Repeater Mode
    Posted Sep 07, 2012 06:48 PM
    Could you please elaborate on your second question?
    What is the use-case?
  • 4.  RE: Newbie-Question: IAP-93 Manuals and Repeater Mode
    Posted Sep 07, 2012 06:57 PM
    I have an existing Wifi network with less coverage in a lower level in my house. Is it possible to configure the IAP-93 as an extender of this Wifi network, so that the devices connect to the main wifi router OR the IAP-93 depending where they are in the house.
    I want to use the IAP-93 to extend the coverage of my Wifi network.
  • 5.  RE: Newbie-Question: IAP-93 Manuals and Repeater Mode
    Posted Sep 07, 2012 06:49 PM
    Cool, thanks! Found it!
  • 6.  RE: Newbie-Question: IAP-93 Manuals and Repeater Mode
    Posted Sep 07, 2012 07:30 PM
    Let me check on the WIFI uplink feature in the upcoming release and get back to you. What is the make and model of your WIFI router?
  • 7.  RE: Newbie-Question: IAP-93 Manuals and Repeater Mode
    Posted Sep 08, 2012 02:48 AM
    Right now it's a Netgear WDNR4500, 2.4 GHz band. But perhaps I'll change to an AVM FritzBox 7390 (2.4 GHz, too).
  • 8.  RE: Newbie-Question: IAP-93 Manuals and Repeater Mode
    Posted Sep 13, 2012 12:30 PM
    Hi there!
    Any news?
    Thanks!
  • 9.  RE: Newbie-Question: IAP-93 Manuals and Repeater Mode
    Posted Sep 15, 2012 07:19 PM
    The "WiFi Uplink" feature is a roadmap item.   It will not be in the release scheduled for the end of September but should be coming soon.
  • 10.  RE: Newbie-Question: IAP-93 Manuals and Repeater Mode
    Posted Sep 16, 2012 06:02 AM
    Thanks a lot!
