Newbies Question - Configuring new SSID
  • 1.  Newbies Question - Configuring new SSID
    Posted Nov 22, 2011 08:55 AM
    We've bee using a 600 controller for about 6 months now and it was orginally installed by a 3rd party unfortunately as of yet we haven't been able to get any training on the kit so I'm now blindly trying to configure a new SSID.
    I've used the wizard and configured a new VLAN and given the VLAN an IP address, I can ping the address from the network but none of the AP's are broadcasting the new SSID. The SSID is enabled and doesn't have hide SSID.
    What have I missed in the config that I need to do to get the new SSID working?
    Jon
  • 2.  RE: Newbies Question - Configuring new SSID
    Posted Nov 22, 2011 09:01 AM
    When you used the wizard, you should have added the SSID to the AP group that the access points are in already, otherwise it will not broadcast.
  • 3.  RE: Newbies Question - Configuring new SSID
    Posted Nov 22, 2011 09:06 AM
    Did you provision the access points?
    Is the SSID (aka Virtual AP Profile) applied to the default AP profile? Or did you create a new AP group?
    Which AP model are you using? Some APs come in as unprovisioned, as opposed to automatically being provisioned in the default AP group.
