I have gone through the Wizard in the Mobility Controller to add a new WLAN/SSID. However I do not see it after adding it. When I try to add it again, I am told that it already exists.
Am I missing something? I have already set up the IPs, VLANs, etc. for this SSID.
Thanks!
what is the output of " show wlan ssid-profile " ?
Are you able to see the configured SSID here?
--Give Kudos: found something helpful, important, or cool? Click Kudos Star in a post.--Problem Solved? Click "Accepted Solution" in a post.
