Newly converted IAPs to Campus APs registers the controller as Air Monitor APs.
  • 1.  Newly converted IAPs to Campus APs registers the controller as Air Monitor APs.
    Posted Apr 23, 2017 10:39 AM
    I have a setup wherein the country code is different from the country code defined under the regulatory domain of AP groups and it is working fine with my setup of over 200 + APs. So the requirement of having both as same appears not as an compulsion link
    I have recently converted over 20+ Instant APs to Campus APs to register with the controller. The problem is they all are showing up as Air Monitors.
    Below is the radio related configuration:
    (WLC_001) #show country
    Country:QA
    Model:Aruba7240XM
    Hardware:Unrestricted
    (WLC_001) #show ap-group APC
    AP group "APC"
    Parameter Value
    Virtual AP VAP1
    Virtual AP VAP2-vap_prof
    Virtual AP GUEST-vap_prof
    802.11a radio profile default
    802.11g radio profile default
    Ethernet interface 0 port configuration default
    Ethernet interface 1 port configuration default
    Ethernet interface 2 port configuration shutdown
    Ethernet interface 3 port configuration shutdown
    Ethernet interface 4 port configuration shutdown
    AP system profile default
    VoIP Call Admission Control profile default
    802.11a Traffic Management profile N/A
    802.11g Traffic Management profile N/A
    Regulatory Domain profile default
    RF Optimization profile default
    RF Event Thresholds profile default
    IDS profile default
    Mesh Radio profile default
    Mesh Cluster profile N/A
    Provisioning profile N/A
    AP authorization profile N/A
    (WLC_001) #show ap regulatory-domain-profile "default"
    Regulatory Domain profile "default"
    Parameter Value
    Country Code US
    Valid 802.11g channel 1
    Valid 802.11g channel 6
    Valid 802.11g channel 11
    Valid 802.11a channel 36
    Valid 802.11a channel 40
    Valid 802.11a channel 44
    Valid 802.11a channel 48
    Valid 802.11a channel 149
    Valid 802.11a channel 153
    Valid 802.11a channel 157
    Valid 802.11a channel 161
    Valid 802.11a channel 165
    Valid 802.11g 40MHz channel pair N/A
    Valid 802.11a 40MHz channel pair N/A
    Valid 802.11a 80MHz channel group N/A
    Valid 802.11a 160MHz channel group N/A
    (WLC_001) #show rf dot11a-radio-profile default
    802.11a radio profile "default"
    Parameter Value
    Radio enable Enabled
    Mode ap-mode
    High throughput enable (radio) Enabled
    Very high throughput enable (radio) Enabled
    Channel N/A
    Transmit EIRP 20 dBm
    Non-Wi-Fi Interference Immunity 2
    Spur Immunity 0
    Enable CSA Disabled
    CSA Count 4
    Spectrum Monitoring Disabled
    Smart Antenna Enabled
    Spectrum Monitoring Profile default-a
    Advertise 802.11d and 802.11h Capabilities Disabled
    Spectrum Load Balancing Disabled
    Spectrum Load Balancing Mode channel
    Spectrum Load Balancing Update Interval (sec) 30 seconds
    Spectrum Load Balancing Threshold (%) 20 percent
    Spectrum Load Balancing Domain N/A
    Beacon Period 100 msec
    Beacon Regulate Disabled
    Advertized regulatory max EIRP 0
    ARM/WIDS Override OFF
    Reduce Cell Size (Rx Sensitivity) 0 dB
    Energy Detect Threshold Offset 0 dB
    Management Frame Throttle interval 1 sec
    Management Frame Throttle Limit 20
    Maximum Distance 0 meters
    RX Sensitivity Threshold 0 dB
    RX Sensitivity Tuning Based Channel Reuse disable
    Adaptive Radio Management (ARM) Profile default-a
    High-throughput Radio Profile default-a
    AM Scanning Profile default
    (WLC_001) #show rf dot11g-radio-profile default
    802.11g radio profile "default"
    Parameter Value
    Mode ap-mode
    Very high throughput rates enable (256-QAM) Disabled
    Channel N/A
    Enable CSA Disabled
    CSA Count 4
    Spectrum Monitoring Profile default-g
    Protection for 802.11b Clients Enabled
    Adaptive Radio Management (ARM) Profile default-g
    High-throughput Radio Profile default-g
    (WLC_001) #show ap system-profile default
    AP system profile "default"
    Parameter Value
    RF Band g
    RF Band for AM mode scanning all
    Native VLAN ID 1
    Tunnel Heartbeat Interval 1
    Session ACL ap-uplink-acl
    Corporate DNS Domain N/A
    SNMP sysContact N/A
    LED operating mode (11n/11ac APs only) normal
    LED override Disabled
    Driver log level warnings
    Console log level emergencies
    SAP MTU 1200 bytes
    RAP MTU 1200 bytes
    LMS IP 192.168.0.12
    Backup LMS IP 192.168.0.11
    LMS IPv6 N/A
    Backup LMS IPv6 N/A
    LMS Preemption Enabled
    LMS Hold-down Period 600 sec
    LMS ping interval 20
    Remote-AP DHCP Server VLAN N/A
    Remote-AP DHCP Server Id 192.168.11.1
    Remote-AP DHCP Default Router 192.168.11.1
    Remote-AP DHCP DNS Server N/A
    Remote-AP DHCP Pool Start 192.168.11.2
    Remote-AP DHCP Pool End 192.168.11.254
    Remote-AP DHCP Pool Netmask 255.255.255.0
    Remote-AP DHCP Lease Time 0 days
    Remote-AP uplink total bandwidth 0 kbps
    Remote-AP bw reservation 1 N/A
    Remote-AP bw reservation 2 N/A
    Remote-AP bw reservation 3 N/A
    Remote-AP Local Network Access Disabled
    Bootstrap threshold 32
    Double Encrypt Disabled
    Dump Server N/A
    Heartbeat DSCP 0
    Maintenance Mode Disabled
    Maximum Request Retries 10
    Request Retry Interval 10 sec
    Number of IPSEC retries 85
    Secondary Master IP/FQDN N/A
    AeroScout RTLS Server N/A
    RTLS Server configuration N/A
    RTLS Server Compatibility Mode Enabled
    Slow Timer Recovery by rebooting itself Disabled
    Telnet Enabled
    Disable RAP Tftp Image Upgrade Disabled
    Spanning Tree Disabled
    AP multicast aggregation Disabled
    AP ARP attack protection Disabled
    AP multicast aggregation allowed VLANs none
    Console enable Enabled
    AP Console Protection Enabled
    AP Console Password ********
    Password for Backup ********
    AP USB Power override Disabled
    RF Band for Backup all
    Operation for Backup off
    BLE Endpoint URL N/A
    BLE Auth Token N/A
    BLE Operation Mode Disabled
  • 2.  RE: Newly converted IAPs to Campus APs registers the controller as Air Monitor APs.
    Posted Apr 23, 2017 10:42 AM
    What was the country code of the IAPs before conversion?
    What model IAPs are these?
    What version of controller code?
  • 3.  RE: Newly converted IAPs to Campus APs registers the controller as Air Monitor APs.
    Posted Apr 23, 2017 11:52 AM
    1) From the AP box the description I see is: ARuba IAP-315(RW).Not sure if this mean to signify "rest of the world".
    Below is the network log for one of the AP which comes up as Airmonitor after its conversion from IAP to Campus AP
    (WLC_002) #show log system 50 | include a8:bd:27:c1:81:2e
    Apr 23 13:31:32 :311002: <WARN> |AP a8:bd:27:c1:81:2e@172.25.98.50 sapd| Rebooting: Rebooting after provisioning
    Apr 23 13:33:59 :399803: <4012> <ERRS> |stm| An internal system error has occurred at file sapm_ap_mgmt.c function sapm_proc_hello_req line 12411 error Mismatched Regulatory Domain for AP(a8:bd:27:c1:81:2e), Ctrl CC(US) AP CC(RW). AP will come up in AM Mode .
    2) These are IAP-315
    3) The version of Controller code is : 6.5.0.2
  • 4.  RE: Newly converted IAPs to Campus APs registers the controller as Air Monitor APs.
    Posted Apr 23, 2017 01:28 PM
    IAPs that were ROW  but now converted to campus, cannot come up in an ap-group that is US...
  • 5.  RE: Newly converted IAPs to Campus APs registers the controller as Air Monitor APs.
    Posted Apr 24, 2017 02:53 AM
    As always, thanks Joseph for your prompt help.
    Your responses and resolutions are faster than TAC :)
