Higher Education
last person joined: 24 days ago
Got questions on how to enable mobility in education? Submit them here!
Next Question ;-) MAC auth for hardwired clients?
  • 1.  Next Question ;-) MAC auth for hardwired clients?
    Posted Jun 28, 2016 10:00 AM
    Has anyone done this? Or, does someone know how to configure this up for hardwired clients and could enlighten me? Preferably using the user derivation rules if possible...
    As always, thanks to anyone who responds!
  • 2.  RE: Next Question ;-) MAC auth for hardwired clients?
    MVP
    Posted Jun 28, 2016 10:15 AM
    Attempting email reply.
    We do MAC auth & 802.1X on Cisco switch ports. We do not (yet) do RADIUS CoA
    By default the switch will try 802.1X & then MAC auth. Since the 802.1X timeout is so long, we use the following port configuration.
    authentication order mab dot1x
    authentication priority dot1x mab
    This tells the switfch to try MAC auth first, but switch to 802.X if it receives an EAP packet.
    Bruce Osborne
    Wireless Engineer
    IT Network Services - Wireless
    (434) 592-4229
    [http://www.liberty.edu/media/1616/40themail/wordmark-for-email.jpg]
    Training Champions for Christ since 1971
  • 3.  RE: Next Question ;-) MAC auth for hardwired clients?
    MVP
    Posted Jun 28, 2016 10:30 AM
    We use ClearPass & register the mac auth devices as Known Endpoints.
    We also associate a username to the device so we can monitor Internet usage per user.
  • 4.  RE: Next Question ;-) MAC auth for hardwired clients?
    Posted Jun 28, 2016 10:24 AM
    So you want to manually register non-1X capable devices? Is this with ClearPass?
  • 5.  RE: Next Question ;-) MAC auth for hardwired clients?
    @cappalli - yes, exactly, and controller only, no clearpass. If this were a clearpass set up I would do it differently as I would have a lot more options.
  • 6.  RE: Next Question ;-) MAC auth for hardwired clients?
    MVP
    Posted Jun 28, 2016 10:32 AM
    What system/database are you going to use for registration?
    Bruce Osborne
    Wireless Engineer
  • 7.  RE: Next Question ;-) MAC auth for hardwired clients?
    Posted Jun 28, 2016 10:48 AM
    Bruce Osborne
    Wireless Engineer
    @bosborne - the end devices are not capable of any other sort of authentication, they are online, they have a mac address and an ip address, i need to secure them. If this were a ClearPass environment, I would add the devices as known endpoints and go that route but this is not such an environment. This is a controller only network and I was thinking about using the user derivation rules for mac lists.
    The wireless side, no worries, done. Hard line side though, got three VLANs coming in, say VLAN 100, 200 & 300. The devices on these VLANs are not capable of authentication on their own, hence looking at MAC authentication. I was thinking about the user derivation rules as then I could create static mac lists for each VLAN. (also, not talking about hundreds of devices per VLAN, maybe 20 to 30).
    Anyway, I need them to authenticate somehow so that I can put them in a role and then manipulate as per normal (inter-vlan routing, session firewall ACLs, etc...) Make sense?
  • 8.  RE: Next Question ;-) MAC auth for hardwired clients?
    MVP
    Posted Jun 28, 2016 10:52 AM
    Yeah. The switch does mac auth due to the “dumb” client. I believe the switch needs an authentication server to perform the lookup, though.
    You mention a controller. Are you connecting these devices directly to the controller? I am confused about the architecture here.
    Bruce Osborne
    Wireless Engineer
    IT Network Services – Wireless
    Liberty University
  • 9.  RE: Next Question ;-) MAC auth for hardwired clients?
    Posted Jun 28, 2016 11:12 AM
    Bruce Osborne
    Wireless Engineer
    Liberty University
    Maybe this will help!
  • 10.  RE: Next Question ;-) MAC auth for hardwired clients?
    Posted Jun 28, 2016 04:29 PM
    So is the diagram I posted possible? Could it be made to work? Would I need a Mobility Access Switch?
    Or am I trying to do something the controller is just not capable of. That's what I need to figure out.
    I need a drink...
  • 11.  RE: Next Question ;-) MAC auth for hardwired clients?
    Posted Jun 28, 2016 09:43 PM
    The best way to do this is at the switch using clearpass or another database for authentication.  Having the controller try to enforce access upstream from the switch still allows any device on a switchport to communicate with other devices.  User defined mac address rules do not scale, because they are tedious to maintain...
