Check
this video and
this datasheet. Edge Connect has built-in NGFW features, can integrate with cloud security (SASE/SSE), can policy based route through an on-premise external NGFW, and allows backhauling traffic as well, so you have full flexibility. I can't see your exact requirements, but with these options I'm confident that you can meet those. Please work with your local Aruba partner or Aruba Sales team to design your optimal solution.
Original Message:
Sent: Jan 06, 2023 03:14 PM
Subject: NGFW integration
I want to provide good edge security to my network, so I would normally use some form of NGFW (e.g. Palo Alto) at each point of connection to the internet. As I understand it, Edge Connect appliances provide encryption and stateful firewalling, but while I could just rely on tht, if I have high-security traffic, I need to either put the Edge Connect behind an NGFW before I connect the Internet, or backhaul the traffic to a central site, then access the Internet via a single (ha-pair) of NGWF, though this means that on-site DIA internet connection (local breakout) is not possible.
Is my understandng correct, or is there some element of NGFW *inside* the Edge Connect
Roo
