no APs after 6.1.3.0 upgrade
  • 1.  no APs after 6.1.3.0 upgrade
    Posted Feb 23, 2012 08:24 AM
    This morning I upgraded 8 controllers (1 master, 7 local) to version 6.1.3.0 of ArubaOS. Everything recovered just fine except for one local controller did not regain control of any of its APs. The controller appears to be just sitting idle. I have reloaded it twice more with no improvement.
    I also see this as one of the last messages in the logs:
    Feb 23 07:57:07  stm[1828]: <304001> <ERRS> |stm|  Unexpected stm (Station management) runtime error at data_path_handler, 633, data_path_handler: recv - Network is down
    I am on the CLI via SSH so I know that the network is not actually down. Nothing was changed config wise.
    Any ideas?
    Dave
  • 2.  RE: no APs after 6.1.3.0 upgrade
    Posted Feb 23, 2012 09:05 AM
    I just fixed the problem by causing VRRP to change states. The local controller is master again and has its APs back.
    Is there an easy command to manually failover vrrp?
    I used:
    vrrp 1
    preempt
    exit
    Since the local had a higher priority, it took over as I intended.
    Then I removed the preempt command "no preempt", as to keep the configuration consistent across our devices.
    Dave
  • 3.  RE: no APs after 6.1.3.0 upgrade
    Posted Feb 23, 2012 10:22 AM
    You can manually shutdown the VRRP.
     (config) #vrrp 1
    (config-vrrp)#shutdown
    If you shutdown the VRRP, the virtual Ip address will failover to the standby controller and vice versa
