No Authentication Captive Portal with Welcome Page
  • 1.  No Authentication Captive Portal with Welcome Page
    Posted May 16, 2012 12:44 PM
    I am deploying free Wi-Fi in a public location.  Our PR department wants a landing page to corporate website.  That is, after a user click on “I ACCEPT”, the browser redirect to a page as designated in captive portal profile “welcome page”.  It works for almost all devices except the Apple iOS.  After user click "I ACCEPT", role changes to "guest", Safari will browse the Internet, but no redirect to corporate landing page.
    Any ideas?
    My AOS 6.1.2.3
    My index.html is from this http://support.arubanetworks.com/ArubaOSKB/tabid/111/Default.aspx
    My captive portal profile:
    (MASTER) #show aaa authentication captive-portal BTNRHGUEST-CP
    Captive Portal Authentication Profile "BTNRHGUEST-CP"
    Parameter                                     Value
    Default Role                                  OPENEDGUEST-LOGON
    Default Guest Role                            guest
    Server Group                                  default
    Redirect Pause                                10 sec
    User Login                                    Disabled
    Guest Login                                   Enabled
    Logout popup window                           Disabled
    Use HTTP for authentication                   Disabled
    Logon wait minimum wait                       5 sec
    Logon wait maximum wait                       10 sec
    logon wait CPU utilization threshold          60 %
    Max Authentication failures                   0
    Show FQDN                                     Disabled
    Use CHAP (non-standard)                       Disabled
    Sygate-on-demand-agent                        Disabled
    Login page                                    /upload/custom/BTNRHGUEST-CP/index.html
    Welcome page                                  http://www.boystownhospital.org
    Show Welcome Page                             No
    Add switch IP address in the redirection URL  Disabled
    Allow only one active user session            Disabled
    Show the acceptable use policy page           Disabled
  • 2.  RE: No Authentication Captive Portal with Welcome Page
    Posted May 17, 2012 05:40 PM
    In your Captive Portal profile, why have you set "Show Welcome-Page" as "NO"? It should be YES.
  • 3.  RE: No Authentication Captive Portal with Welcome Page
    Posted May 17, 2012 06:48 PM
    I tried both, that knob made no different to the welcome page
  • 4.  RE: No Authentication Captive Portal with Welcome Page
    Posted May 17, 2012 06:51 PM
    If this is an IOS device, that is probably because the IOS captive portal network assistant, which prevents subsequent redirects.
    In your "logon" role you need to permit traffic to *.apple.com so that the captive portal network assistant does not launch.
  • 5.  RE: No Authentication Captive Portal with Welcome Page
    Posted May 17, 2012 06:56 PM
    I tried same setup in my LAB and it worked fine. I used controller on 6.1.3.1. Customize CP + External Welcome page (yahoo.com).
    BTW, I did not add apple.com in the logon role but you can give it a shot...
    Can you please upgrade the controller to 6.1.3.1 and check?
    Alap
  • 6.  RE: No Authentication Captive Portal with Welcome Page
    Posted May 21, 2012 09:45 AM
    Thanks both Colin and aalap22.  I am in the process of upgrading to 6.1.3.1.
    Colin, can you be more specific in guest logon role?  I could not do “user host *.apple.com any permit position 2”, so I tried to permit host www.apple.com, 23.33.29.25, and host apple.com 17.149.160.49.  It is probably not a good idea.
    Is it possible to do ACL to allow *.apple.com?
    Best Regards,
    Trinh Nguyen
  • 7.  RE: No Authentication Captive Portal with Welcome Page
    Posted May 22, 2012 07:50 AM
    You can use this:
    config t
    ip domain.name test.com
    ip name-server 8.8.8.8
    ip domain-lookup
    netdestination apple
    name *.apple.com
    After that, you can use the alias "apple" in an ACL to permit traffic.
  • 8.  RE: No Authentication Captive Portal with Welcome Page
    Posted May 22, 2012 10:27 AM
    Safari tried to redirect to welcome page, but error:
    "Safari cannon open the page because too many redirects occurred."
    It cannot redirect to the page for user to click "I ACCEPT
    This is strange: the problem is only at the LOCAL controller.  APs associated to master-controller worked !
  • 9.  RE: No Authentication Captive Portal with Welcome Page
    Posted May 22, 2012 12:31 PM
    It works after upload the customer page "index.html" to every LOCAL CONTROLLERS.
    Thanks all for your help!
