No command 'show netstat' on Aruba OS 6.4.2.4?
  • 1.  No command 'show netstat' on Aruba OS 6.4.2.4?
    Posted Apr 08, 2015 11:59 AM
    I used to use 'show netstat' to see current tcp/udp connections on a Aruba controller to troubleshoot network connection issues. Since upgraded to 6.4, the command is nolonger available. The only option left is 'show netstat stats', which displays stats and no current connections and listening ports. Is there an alternative command/way I can use to get the connection information?
    (CamL1) #show netstat
    % Incomplete command.
    (CamL1) #show netstat ?
    stats                   Show netstat statistics
    Thank you.
    Yu
  • 2.  RE: No command 'show netstat' on Aruba OS 6.4.2.4?
    Posted Apr 08, 2015 12:08 PM
    I think you are looking for
    # show datapath session table
    _ELiasz
  • 3.  RE: No command 'show netstat' on Aruba OS 6.4.2.4?
    Posted Apr 08, 2015 03:37 PM
    ELiasz,
    Thank you.
    Do you know if 'show datapath session table' outputs same connection information as 'show netstat'? I used to get output from 'show netstat' like this one:
    (Local5) #show netstat
    Active Internet connections (servers and established)
    Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
    tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      3369/mysqld
    tcp        0      0 xxx.xxx.xxx.235:8081    yyy.yyy.yyy.202:50338   SYN_RECV    -
    tcp        0      0 xxx.xxx.xxx.235:8081    10.10.241.8:57837     SYN_RECV    -
    tcp        0      0 xxx.xxx.xxx.235:8081    yyy.yyy.yyy.234:52716   SYN_RECV    -
    tcp        0      0 xxx.xxx.xxx.235:8081    yyy.yyy.yyy.202:50335   SYN_RECV    -
    tcp        0      0 xxx.xxx.xxx.235:8081    yyy.yyy.yyy..76:56333    SYN_RECV    -
    tcp        0      0 0.0.0.0:17              0.0.0.0:*               LISTEN      3395/isakmpd
    tcp        0      0 0.0.0.0:8211            0.0.0.0:*               LISTEN      3337/cfgm
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      3595/dnsmasq
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      3571/sshd
    tcp        0      0 0.0.0.0:23              0.0.0.0:*               LISTEN      3324/fpcli
    tcp        0      0 0.0.0.0:8088            0.0.0.0:*               LISTEN      3587/qpdq
    tcp        0      0 0.0.0.0:1723            0.0.0.0:*               LISTEN      3592/pptpd
    tcp        0      0 xxx.xxx.xxx.235:52721   xxx.xxx.xxx.200:8211    ESTABLISHED 3337/cfgm
    tcp        0      0 xxx.xxx.xxx.215:22      10.10.33.152:56791    ESTABLISHED 4360/0
    tcp        0      0 :::8080                 :::*                    LISTEN      3880/httpd
    tcp        0      0 :::80                   :::*                    LISTEN      3880/httpd
    tcp        0      0 :::8081                 :::*                    LISTEN      3880/httpd
    tcp        0      0 :::8084                 :::*                    LISTEN      3880/httpd
    tcp        0      0 :::53                   :::*                    LISTEN      3595/dnsmasq
    tcp        0      0 :::22                   :::*                    LISTEN      3571/sshd
    tcp        0      0 :::1111                 :::*                    LISTEN      3880/httpd
    tcp        0      0 :::4343                 :::*                    LISTEN      3880/httpd
    tcp        0      0 :::23                   :::*                    LISTEN      3324/fpcli
    tcp        0      0 :::443                  :::*                    LISTEN      3880/httpd
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..192:42965 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8080 ::ffff:yyy.yyy.yyy.202:50395 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy.202:50406 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..76:56324 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy.202:50387 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..76:56313 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..76:56253 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy.168:53592 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8080 ::ffff:yyy.yyy.yyy.251:43858 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..76:56310 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:10.10.243.13:57241 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..76:56241 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..76:56244 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8080 ::ffff:yyy.yyy.yyy.202:50388 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..76:56247 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy.163:32975 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8080 ::ffff:yyy.yyy.yyy..76:56277 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..76:56312 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy.202:50392 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy.148:56037 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..76:56317 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..76:56292 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy.21:52420 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..76:56311 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..76:56239 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy.223:56442 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..76:56265 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..61:44247 FIN_WAIT2   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..76:56285 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..76:56263 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..76:56255 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8080 ::ffff:yyy.yyy.yyy..61:33838 TIME_WAIT   -
    tcp        0      0 ::ffff:xxx.xxx.xxx.235:8081 ::ffff:yyy.yyy.yyy..76:56326 TIME_WAIT   -
    Yu
  • 4.  RE: No command 'show netstat' on Aruba OS 6.4.2.4?
    Posted Apr 08, 2015 03:56 PM
    ELiasz,
    Thank you.
    Do you know if 'show datapath session table' outputs same active connection information as 'show netstat'? I used to get output from 'show netstat' like this one:
    Yu
  • 5.  RE: No command 'show netstat' on Aruba OS 6.4.2.4?
    Posted Apr 13, 2015 09:19 AM
    I opened a call with Support (1674790) and here is my interpretation of what I was told:
    The Aruba Development team made a decision to discontinue support for “show netstat” due to the load it places on the CPU.  The problem caused by “show netstat” was so urgent that there was no time to retire the command gracefully, for instance by deprecating it first, and no time to change the documentation for 6.4.  There are no plans to replace the functionality of “show netstat” but they will continue to support “show netstat stats”.
  • 6.  RE: No command 'show netstat' on Aruba OS 6.4.2.4?
    Posted Apr 13, 2015 11:42 AM
    Doug, Thanks.
    If 'show netstat' cause cpu spikes, then maybe assign the process to a cpu other than 0? Controller 7240 has 8 cpus. Anyway, thanks for checking with Aruba.
