NO DHCP after connected to WIFI
  • 1.  NO DHCP after connected to WIFI
    Posted Sep 27, 2019 05:45 AM
    Hello Experts,
    i have 2 site, site A and site B, controller is found on site A, both site are link via an SD-WAN, controller can see AP from both site, but on site B is not getting IP from site b dhcp server, the SSID has vlan 300 enable which is site b user vlan. any idea how to make it works?
  • 2.  RE: NO DHCP after connected to WIFI
    Posted Sep 27, 2019 06:12 AM
    Is the WLAN at site B in tunnel or bridge mode?
  • 3.  RE: NO DHCP after connected to WIFI
    Posted Sep 27, 2019 06:19 AM
    a bridge
  • 4.  RE: NO DHCP after connected to WIFI
    Posted Sep 27, 2019 06:42 AM
    Ok. How are your AP switchports configured? Trunk? Access?
    What VLAN is set in your VAP?
    What VLAN is set here for site B APs: AP-Group> AP> System Profile> Native VLAN
  • 5.  RE: NO DHCP after connected to WIFI
    Posted Sep 27, 2019 06:47 AM
    AP are access type, vlan 300, native vlan 1, the AP IP is on vlan 320 which is ip 192.168.32.1/23
  • 6.  RE: NO DHCP after connected to WIFI
    Posted Sep 27, 2019 07:17 AM
    Generally, when you set your VAP to bridge mode you either:
    - bridge traffic at your AP untagged
    - bridge traffic at your AP tagged
    If you want your Wi-Fi traffic to exit your AP untagged (e.g. on the same subnet as your AP) set your VLAN to 1 in your VAP.
    If you want your Wi-Fi traffic to exit your AP tagged (e.g. on a different VLAN/subnet as your AP) set your VLAN to 300 in your VAP & configure your switchport your AP is patched into as a trunk port with native VLAN 320 (AP VLAN) & tagged VLAN 300 (Client VLAN).
  • 7.  RE: NO DHCP after connected to WIFI
    Posted Sep 27, 2019 07:38 AM
    i set the native vlan to 300, on profiles, I'm getting ip from VLAN 320 which is 192.168.32.1/24 but my SSID is on VLAN 300, the DHCP IP should be 192.168.30.1/24, shall the VLAN on the interface have an IP?, my switch port has default native VLAN 1, I have several VLAN on it, 10 in total, SITE A have VLAN 106 as management VLAN, all AP is on it, on-site A everything works perfectly, each SSID can get ip from their respected VLAN. should I still change the native VLAN of my switch to 300? I have configured only one port for all these VLAN.
  • 8.  RE: NO DHCP after connected to WIFI
    Posted Sep 27, 2019 10:15 AM
    If the VLAN set in your VAP matches the VLAN set here: AP-Group> AP> System Profile> Native VLAN then the traffic will exit the AP untagged which sounds like what is happenning.
    To fix it do this:
    Set this to 1: Sita B AP-Group> AP> System Profile> Native VLAN
    Set the VAP VLAN to 300.
    Ensure the switchport the AP is patched into is configured as a trunk and VLAN 300 is tagged.
  • 9.  RE: NO DHCP after connected to WIFI
    Posted Sep 27, 2019 10:16 AM
  • 10.  RE: NO DHCP after connected to WIFI
    Posted Sep 27, 2019 11:08 AM
    The VLAN 300 and 320 are
    found at site B, on SITE A, core switch should I  tagged VLAN 320 and 300 to the trunk that connects the master controller?
  • 11.  RE: NO DHCP after connected to WIFI
    Posted Sep 30, 2019 04:51 AM
    As you've previously said your virtual AP profile for site B is in bridge mode, your site B VLANs don't need to exist at site A.
  • 12.  RE: NO DHCP after connected to WIFI
    Posted Sep 30, 2019 08:10 AM
    To fix it do this:
    When I tried this, I didn't get IP, I must set the profile to native VLAN 300 to get IP from VLAN 320, I'm not understanding, how to make it work on VLAN 300, I must get VLAN 300 IP on the AP when connected to it. VAP is set to VLAN 300. my switch port native VLAN is 1, on-site A everything works perfectly, its only on-site B im getting this issue.
  • 13.  RE: NO DHCP after connected to WIFI
    Posted Sep 30, 2019 08:11 AM
    I`m using Aruba OS 8.5
  • 14.  RE: NO DHCP after connected to WIFI
    Posted Sep 30, 2019 10:13 AM
    WOuld you share some of your config so I can see how it's currently setup?
    On your controller CLI can you run: show wlan virtual-ap <site B VAP name> and post the output?
    Also can you post the CLI config of the switchport that your AP at site B is patched into?
  • 15.  RE: NO DHCP after connected to WIFI
    Posted Oct 01, 2019 02:04 AM
    (Arubamaster) [mynode] #show wlan virtual-ap "unity warehouse"
    Virtual AP profile "Unity Warehouse"
    Parameter Value
    AAA Profile Unity Warehouse_aaa_prof
    802.11k Profile default
    Hotspot 2.0 Profile N/A
    Virtual AP enable Enabled
    VLAN 300
    Forward mode bridge
    SSID Profile Unity Warehouse_ssid_prof
    Allowed band all
    Band Steering Disabled
    Cellular handoff assist Disabled
    Openflow Enable Enabled
    Steering Mode prefer-5ghz
    Dynamic Multicast Optimization (DMO) Disabled
    Dynamic Multicast Optimization (DMO) Threshold 6
    Drop Broadcast and Multicast Disabled
    Convert Broadcast ARP requests to unicast Enabled
    Authentication Failure Blacklist Time 3600 sec
    --More-- (q) quit (u) pageup (/) search (n) repeat
    Deny inter user traffic Disabled
    Deny time range N/A
    DoS Prevention Disabled
    HA Discovery on-association Enabled
    Mobile IP Enabled
    Preserve Client VLAN Disabled
    Remote-AP Operation standard
    Station Blacklisting Enabled
    Strict Compliance Disabled
    VLAN Mobility Disabled
    WAN Operation mode always
    FDB Update on Assoc Disabled
    WMM Traffic Management Profile N/A
    Anyspot profile N/A
    interface gigabitethernet 0/0/4
    description "MAIN-FIBRE"
    trusted
    trusted vlan 1-4094
    no poe
    switchport mode trunk
    switchport access vlan 106
    native vlan 1
  • 16.  RE: NO DHCP after connected to WIFI
    Posted Oct 01, 2019 04:35 AM
    You don't have VLAN 300 trunked to your AP. Add VLAN 300 as an allowed trunk VLAN.
    switchport trunk allowed vlan 300
  • 17.  RE: NO DHCP after connected to WIFI
    Posted Oct 01, 2019 04:48 AM
    ALso just to check the other settings which could affect things.. Can you check what AP group your site B APs are in?
    Then post the following:
    show ap-group <site B ap group>
    show ap system-profile <profile used in above ap group>
  • 18.  RE: NO DHCP after connected to WIFI
    Posted Oct 01, 2019 04:59 AM
    where shall I run this command? : switchport trunk allowed vlan 300 on the interface?
    Arubamaster) [mynode] (config) #show ap-group "JIN FEI"
    AP group "JIN FEI"
    Parameter Value
    Virtual AP Unity Warehouse
    Virtual AP Unity Guest
    Virtual AP Radio
    802.11a radio profile JIN FEI_radio_a_ui
    802.11g radio profile JIN FEI_radio_g_ui
    802.11 60GHz radio profile default
    Ethernet interface 0 port configuration default
    Ethernet interface 1 port configuration default
    Ethernet interface 2 port configuration shutdown
    Ethernet interface 3 port configuration shutdown
    Ethernet interface 4 port configuration shutdown
    Ethernet usb port configuration shutdown
    AP system profile JIN FEI_apsys_ui
    AP multizone profile default
    802.11a Traffic Management profile N/A
    802.11g Traffic Management profile N/A
    Regulatory Domain profile default
    RF Optimization profile default
    RF Event Thresholds profile default
    IDS profile default
    Mesh Radio profile default
    Mesh Cluster profile N/A
    WiFi uplink profile N/A
    Provisioning profile N/A
    AP authorization profile N/A
    IoT radio profile N/A
    (Arubamaster) [mynode] (config) #show ap system-profile "JIN FEI_apsys_ui"
    AP system profile "JIN FEI_apsys_ui"
    Parameter Value
    RF Band g
    Recovery Mode auto
    RF Band for AM mode scanning all
    Native VLAN ID 300
    WIDS AMPDU Optimization Enabled
    Tunnel Heartbeat Interval 1
    Session ACL ap-uplink-acl
    Corporate DNS Domain N/A
    SNMP sysContact N/A
    LED operating mode (11n/11ac APs only) normal
    LED override Disabled
    Driver log level warnings
    Console log level emergencies
    SAP MTU N/A
    RAP MTU 1300 bytes
    LMS IP 192.168.106.3
    Backup LMS IP 192.168.106.4
    LMS IPv6 N/A
    Backup LMS IPv6 N/A
    LMS Preemption Disabled
    LMS Hold-down Period 600 sec
    LMS ping interval 20
    Remote-AP DHCP Server VLAN N/A
    Remote-AP DHCP Server Id 192.168.11.1
    Remote-AP DHCP Default Router 192.168.11.1
    Remote-AP DHCP DNS Server N/A
    Remote-AP CORP DNS Server N/A
    Remote-AP CORP DNS Server IPV6 N/A
    Remote-AP DHCP Pool Start 192.168.11.2
    Remote-AP DHCP Pool End 192.168.11.254
    Remote-AP DHCP Pool Netmask 255.255.255.0
    Remote-AP DHCP Lease Time 0 days
    Remote-AP uplink total bandwidth 0 kbps
    Remote-AP bw reservation 1 N/A
    Remote-AP bw reservation 2 N/A
    Remote-AP bw reservation 3 N/A
    Remote-AP Local Network Access Disabled
    Flex Radio Mode 2.4GHz-and-5GHz
    Dual 5GHz Mode Enabled
    IPM activation Disabled
    IPM power reduction steps with priorities N/A
    IPM Steps delete all No
    Bootstrap threshold 8
    Double Encrypt Disabled
    Heartbeat DSCP 0
    Management DSCP N/A
    IP DSCP to VLAN 802.1p priority mapping N/A
    Maintenance Mode Disabled
    Maximum Request Retries 10
    Request Retry Interval 10 sec
    Number of IPSEC retries 85
    Secondary Master IP/FQDN N/A
    AeroScout RTLS Server N/A
    RTLS Server configuration N/A
    RTLS Server Compatibility Mode Enabled
    SES-imagotag ESL Server IP N/A
    SES-imagotag ESL Channel N/A
    SES-imagotag ESL Radio Coexistence Enabled
    Slow Timer Recovery by rebooting itself Enabled
    Telnet Enabled
    Disable RAP Tftp Image Upgrade Disabled
    Image URL N/A
    Spanning Tree Disabled
    AP multicast aggregation Enabled
    AP ARP attack protection Disabled
    AP multicast aggregation allowed VLANs 300,320
    Console enable Enabled
    AP Console Protection Enabled
    AP Console Password ********
    Password for Backup ********
    AP USB Power mode auto
    AP POE mode shared
    RF Band for Backup all
    Operation for Backup off
    BLE Operation Mode Disabled
    GRE offload Enabled
    Bridge offload Enabled
    Health Check Disabled
    Health Check Parameter mode ping packet-size 32 burst-size 5 report 60 frequency 10 retries 3
    AirMatch Report Period 30 minutes
    AirMatch Measurement Duration 5 minutes
    AirMatch Report Enabled Enabled
    AP Deploy-hour N/A
    Dump collection profile default
  • 19.  RE: NO DHCP after connected to WIFI
    Posted Oct 01, 2019 05:32 AM
    As you are bridging traffic on your (unity warehouse) virtual AP profile and you want your APs to be on a different VLAN to your clients, you need to trunk your client VLAN (300) to each AP at site B that uses this virtual AP profile.
    To fix it do this:
    1. Set this to 1: Sita B AP-Group> AP> System Profile> Native VLAN
    2. Ensure the switchport the AP(s) is patched into is configured as a trunk and VLAN 300 is tagged.
    I'm assuming that VLAN 300 existing at SIte B and if a device is placed in VLAN 300, on the switch that you're testing with, it would receive an IP address.
  • 20.  RE: NO DHCP after connected to WIFI
    Posted Oct 01, 2019 06:18 AM
    I'm confused - even after reading all posts by you and James :D
    1. This is the IAP forum, but it looks like these AP's are in Campus mode controller by the Controller at Site A.
    2. You are saying the sites are connected using SD-WAN. Is this SD-WAN from Aruba or from somewhere else?
    Regardless - I'm pretty sure James has said whats need to be done.
    In Bridge mode - root of all that is evil - the AP's doesn't behave like normal.. If you set the VAP in Bridge and Clients are to be placed in VLAN 300 - that traffic will exit the AP with VLAN 300 TAGGED.
    Same with VLAN 320. If you do that with BRIDGE and clients set to VLAN 320 - the traffic exiting the AP locally on the switch will be TAGGED vlan 320.
    So..
    VLAN 1 is set to native. This is the VLAN your AP's get their IP address from the local DHCP server.
    Client VLAN 320 and 300 has to be TAGGED/ALLOW TRUNK on the switch-port IF you bridge these two VAP's.
    Clients that are supposed to NOT BE BRIDGE - don't need the VLAN on the switchport as this i sendt north through the tunnel to Controller at Site  A.
  • 21.  RE: NO DHCP after connected to WIFI
    Posted Oct 01, 2019 08:25 AM
    I tried what you asked, still not working traffic is still getting out on VLAN 320, I tested the VLAN 300 switch, I'm able to get DHCP on that VLAN, on my switch where AP is connected, it is untagged on VLAN 320, both VLAN 300 & 320  are trunk on the switch till the firewall. on VLAN 320 I'm able to ping any IP and gateway of VLAN 300.
  • 22.  RE: NO DHCP after connected to WIFI
    Posted Oct 01, 2019 09:00 AM
    Can you show me the switchport configuration of the port the AP is patched into?
    Also can you show the following?
    show ap database | include <ap name you are testing with>
  • 23.  RE: NO DHCP after connected to WIFI
    Posted Oct 02, 2019 02:16 AM
    (Arubamaster) [mynode] #show ap database
    AP Database
    Name Group AP Type IP Address Status Flags Switch IP Standby IP
    7c:57:3c:cb:b5:44 Somatrans 303 192.168.106.150 Down 2 192.168.106.3 0.0.0.0
    ACD-01 RICHETERRE 303 192.168.106.131 Down 2 192.168.106.3 0.0.0.0
    ACD-02 RICHETERRE 303 192.168.106.132 Down 2 192.168.106.3 0.0.0.0
    ACD-03 RICHETERRE 303 192.168.106.133 Down 2 192.168.106.3 0.0.0.0
    ACD-04 RICHETERRE 303 192.168.106.134 Down 2 192.168.106.3 0.0.0.0
    DR-01 RICHETERRE 303 192.168.106.147 Down 2 192.168.106.3 0.0.0.0
    DR-02 RICHETERRE 303 192.168.106.148 Down 2 192.168.106.3 0.0.0.0
    DR-03 RICHETERRE 303 192.168.106.149 Down 2 192.168.106.3 0.0.0.0
    DR-04 RICHETERRE 303 192.168.106.150 Down 2 192.168.106.3 0.0.0.0
    DR-05 default 303 192.168.106.151 Down 2 192.168.106.3 0.0.0.0
    DR-06 RICHETERRE 303 192.168.106.152 Down 2 192.168.106.3 0.0.0.0
    DR-07 RICHETERRE 303 192.168.106.153 Down 2 192.168.106.3 0.0.0.0
    DR-08 RICHETERRE 303 192.168.106.154 Down 2 192.168.106.3 0.0.0.0
    DR-09 RICHETERRE 303 192.168.106.155 Down 2 192.168.106.3 0.0.0.0
    DR-10 RICHETERRE 303 192.168.106.156 Down 2 192.168.106.3 0.0.0.0
    DR-11 default 303 192.168.106.157 Down 2 192.168.106.3 0.0.0.0
    DR-12 RICHETERRE 303 192.168.106.158 Down 2 192.168.106.3 0.0.0.0
    DR-13 RICHETERRE 303 192.168.106.159 Down 2 192.168.106.3 0.0.0.0
    DR-14 RICHETERRE 303 192.168.106.160 Down 2 192.168.106.3 0.0.0.0
    DR-15 RICHETERRE 303 192.168.106.161 Down 2 192.168.106.3 0.0.0.0
    DR-16 RICHETERRE 303 192.168.106.162 Down 2 192.168.106.3 0.0.0.0
    DR-17 RICHETERRE 303 192.168.106.163 Down 2 192.168.106.3 0.0.0.0
    DR-18 RICHETERRE 365 192.168.106.164 Down 2 192.168.106.3 0.0.0.0
    DR-19 RICHETERRE 365 192.168.106.165 Down 2 192.168.106.3 0.0.0.0
    DR-20 RICHETERRE 365 192.168.106.166 Down 2 192.168.106.3 0.0.0.0
    DR-21 RICHETERRE 365 192.168.106.167 Down 2 192.168.106.3 0.0.0.0
    JF-O-1 JIN FEI 303 192.168.32.47 Up 1d:23h:23m:17s 2 192.168.106.3 192.168.106.4
    JF-O-2 JIN FEI 303 192.168.32.48 Up 1d:8h:11m:21s 2 192.168.106.3 192.168.106.4
    JF-WH-01 JIN FEI 365 192.168.32.20 Up 1d:8h:11m:21s 2 192.168.106.3 192.168.106.4
    JF-WH-02 JIN FEI 365 192.168.32.21 Up 1d:8h:11m:21s 2 192.168.106.3 192.168.106.4
    JF-WH-03 JIN FEI 365 192.168.32.22 Down 2 172.16.0.254 0.0.0.0
    JF-WH-04 JIN FEI 365 192.168.32.23 Up 1d:8h:11m:21s 2 192.168.106.3 192.168.106.4
    Flags: 1 = 802.1x authenticated AP use EAP-PEAP; 1+ = 802.1x use EST; 1- = 802.1x use factory cert; 2 = Using IKE version 2
    B = Built-in AP; C = Cellular RAP; D = Dirty or no config
    E = Regulatory Domain Mismatch; F = AP failed 802.1x authentication
    G = No such group; I = Inactive; J = USB cert at AP; L = Unlicensed
    M = Mesh node
    N = Duplicate name; P = PPPoe AP; R = Remote AP; R- = Remote AP requires Auth;
    S = Standby-mode AP; U = Unprovisioned; X = Maintenance Mode
    Y = Mesh Recovery
    c = CERT-based RAP; e = Custom EST cert; f = No Spectrum FFT support
    i = Indoor; o = Outdoor; s = LACP striping; u = Custom-Cert RAP; z = Datazone AP
    p = In deep-sleep status
    4 = WiFi Uplink
    AP Database
    JF-WH-05 JIN FEI 365 192.168.32.24 Up 1d:8h:11m:23s 2 192.168.106.3 192.168.106.4
    JF-WH-06 JIN FEI 365 192.168.32.25 Up 1d:8h:11m:23s 2 192.168.106.3 192.168.106.4
    JF-WH-07 JIN FEI 365 192.168.32.26 Up 1d:8h:11m:23s 2 192.168.106.3 192.168.106.4
    JF-WH-08 JIN FEI 365 192.168.32.27 Up 1d:8h:11m:22s 2 192.168.106.3 192.168.106.4
    JF-WH-09 JIN FEI 365 192.168.32.28 Up 1d:8h:11m:23s 2 192.168.106.3 192.168.106.4
    JF-WH-10 JIN FEI 365 192.168.32.29 Up 20h:36m:41s 2 192.168.106.3 192.168.106.4
    JF-WH-11 JIN FEI 365 192.168.32.30 Up 1d:8h:11m:21s 2 192.168.106.3 192.168.106.4
    JF-WH-12 JIN FEI 365 192.168.32.31 Up 20h:36m:45s 2 192.168.106.3 192.168.106.4
    JF-WH-13 JIN FEI 365 192.168.32.32 Up 1d:8h:11m:23s 2 192.168.106.3 192.168.106.4
    JF-WH-14 JIN FEI 365 192.168.32.33 Up 1d:8h:11m:23s 2 192.168.106.3 192.168.106.4
    JF-WH-15 JIN FEI 365 192.168.32.34 Up 1d:8h:11m:24s 2 192.168.106.3 192.168.106.4
    JF-WH-16 JIN FEI 365 192.168.32.35 Up 1d:8h:11m:23s 2 192.168.106.3 192.168.106.4
    JF-WH-17 JIN FEI 365 192.168.32.36 Up 1d:8h:11m:22s 2 192.168.106.3 192.168.106.4
    JF-WH-18 JIN FEI 365 192.168.32.37 Up 1d:8h:11m:23s 2 192.168.106.3 192.168.106.4
    JF-WH-19 JIN FEI 365 192.168.32.38 Up 1d:8h:11m:24s 2 192.168.106.3 192.168.106.4
    JF-WH-20 JIN FEI 365 192.168.32.39 Up 1d:8h:11m:23s 2 192.168.106.3 192.168.106.4
    JF-WH-21 JIN FEI 365 192.168.32.40 Up 1d:8h:11m:23s 2 192.168.106.3 192.168.106.4
    JF-WH-22 JIN FEI 365 192.168.32.41 Up 1d:8h:11m:22s 2 192.168.106.3 192.168.106.4
    JF-WH-23 JIN FEI 365 192.168.32.42 Up 1d:8h:11m:23s 2 192.168.106.3 192.168.106.4
    JF-WH-24 JIN FEI 365 192.168.32.43 Up 1d:8h:11m:23s 2 192.168.106.3 192.168.106.4
    JF-WH-25 JIN FEI 365 192.168.32.44 Up 1d:8h:11m:23s 2 192.168.106.3 192.168.106.4
    JF-WH-26 JIN FEI 365 192.168.32.45 Up 1d:8h:11m:22s 2 192.168.106.3 192.168.106.4
    JF-WH-27 JIN FEI 365 192.168.32.46 Up 1d:8h:11m:24s 2 192.168.106.3 192.168.106.4
    JIN-TEST JIN FEI 303 1.1.1.17 Down Rc2 192.168.106.3 0.0.0.0
    NW-A-01 RICHETERRE 303 192.168.106.89 Up 12d:22h:0m:18s 2 192.168.106.3 192.168.106.4
    NW-A-02 RICHETERRE 303 192.168.106.90 Up 12d:22h:1m:34s 2 192.168.106.3 192.168.106.4
    NW-A-03 RICHETERRE 303 192.168.106.91 Up 12d:22h:1m:10s 2 192.168.106.3 192.168.106.4
    NW-A-04 RICHETERRE 303 192.168.106.92 Up 5d:15h:30m:35s 2 192.168.106.3 192.168.106.4
    NW-A-05 RICHETERRE 303 192.168.106.93 Up 12d:22h:2m:2s 2 192.168.106.3 192.168.106.4
    NW-A-06 RICHETERRE 303 192.168.106.94 Up 1d:21h:22m:31s 2 192.168.106.3 192.168.106.4
    NW-A-07 RICHETERRE 303 192.168.106.95 Up 12d:22h:1m:27s 2 192.168.106.3 192.168.106.4
    NW-A-08 RICHETERRE 303 192.168.106.96 Up 12d:22h:1m:38s 2 192.168.106.3 192.168.106.4
    M = Mesh node
    Y = Mesh Recovery
    4 = WiFi Uplink
    AP Database
    NW-A-09 RICHETERRE 303 192.168.106.97 Up 12d:22h:3m:42s 2 192.168.106.3 192.168.106.4
    NW-A-10 RICHETERRE 303 192.168.106.98 Up 12d:22h:3m:0s 2 192.168.106.3 192.168.106.4
    NW-A-11 RICHETERRE 303 192.168.106.99 Up 12d:22h:2m:26s 2 192.168.106.3 192.168.106.4
    NW-A-12 RICHETERRE 303 192.168.106.100 Up 12d:22h:23m:31s 2 192.168.106.3 192.168.106.4
    NW-A-13 RICHETERRE 303 192.168.106.101 Up 1d:18h:24m:6s 2 192.168.106.3 192.168.106.4
    NW-A-14 RICHETERRE 303 192.168.106.102 Up 5d:20h:44m:53s 2 192.168.106.3 192.168.106.4
    NW-A-15 RICHETERRE 303 192.168.106.103 Up 12d:22h:0m:48s 2 192.168.106.3 192.168.106.4
    NW-A-16 RICHETERRE 303 192.168.106.104 Up 12d:22h:19m:50s 2 192.168.106.3 192.168.106.4
    NW-A-17 RICHETERRE 303 192.168.106.105 Up 12d:22h:19m:10s 2 192.168.106.3 192.168.106.4
    NW-A-18 RICHETERRE 303 192.168.106.106 Up 1d:17h:22m:41s 2 192.168.106.3 192.168.106.4
    NW-A-19 RICHETERRE 303 192.168.106.107 Down 2 192.168.106.3 0.0.0.0
    NW-B-01 RICHETERRE 303 192.168.106.108 Up 12d:22h:30m:4s 2 192.168.106.3 192.168.106.4
    NW-B-02 RICHETERRE 303 192.168.106.109 Up 12d:22h:31m:0s 2 192.168.106.3 192.168.106.4
    NW-B-03 RICHETERRE 303 192.168.106.110 Up 1d:18h:24m:9s 2 192.168.106.3 192.168.106.4
    NW-B-04 RICHETERRE 303 192.168.106.111 Up 1d:18h:24m:8s 2 192.168.106.3 192.168.106.4
    NW-B-05 RICHETERRE 303 192.168.106.112 Up 12d:22h:29m:32s 2 192.168.106.3 192.168.106.4
    NW-B-06 RICHETERRE 303 192.168.106.113 Up 12d:22h:30m:11s 2 192.168.106.3 192.168.106.4
    NW-B-07 RICHETERRE 303 192.168.106.114 Up 12d:22h:29m:34s 2 192.168.106.3 192.168.106.4
    NW-B-08 RICHETERRE 303 192.168.106.115 Up 12d:22h:27m:43s 2 192.168.106.3 192.168.106.4
    NW-B-09 RICHETERRE 303 192.168.106.116 Up 12d:22h:30m:47s 2 192.168.106.3 192.168.106.4
    NW-B-10 RICHETERRE 303 192.168.106.117 Up 12d:22h:28m:24s 2 192.168.106.3 192.168.106.4
    NW-B-11 RICHETERRE 303 192.168.106.118 Up 12d:22h:28m:32s 2 192.168.106.3 192.168.106.4
    NW-B-12 RICHETERRE 303 192.168.106.119 Up 12d:22h:30m:55s 2 192.168.106.3 192.168.106.4
    NW-C-1 RICHETERRE 303 192.168.106.120 Up 12d:22h:29m:37s 2 192.168.106.3 192.168.106.4
    NW-C-10 RICHETERRE 303 192.168.106.129 Up 12d:22h:27m:56s 2 192.168.106.3 192.168.106.4
    NW-C-11 RICHETERRE 303 192.168.106.130 Up 11d:20h:41m:48s 2 192.168.106.3 192.168.106.4
    NW-C-2 RICHETERRE 303 192.168.106.121 Up 1d:18h:24m:7s 2 192.168.106.3 192.168.106.4
    NW-C-3 RICHETERRE 303 192.168.106.122 Up 12d:22h:29m:27s 2 192.168.106.3 192.168.106.4
    NW-C-4 RICHETERRE 303 192.168.106.123 Up 12d:22h:29m:7s 2 192.168.106.3 192.168.106.4
    NW-C-5 RICHETERRE 303 192.168.106.124 Up 12d:22h:27m:28s 2 192.168.106.3 192.168.106.4
    NW-C-6 RICHETERRE 303 192.168.106.125 Up 1d:22h:43m:20s 2 192.168.106.3 192.168.106.4
    NW-C-7 RICHETERRE 303 192.168.106.126 Up 1d:18h:24m:8s 2 192.168.106.3 192.168.106.4
    M = Mesh node
    Y = Mesh Recovery
    4 = WiFi Uplink
    AP Database
    NW-C-8 RICHETERRE 303 192.168.106.127 Up 1d:18h:24m:7s 2 192.168.106.3 192.168.106.4
    NW-C-9 RICHETERRE 303 192.168.106.128 Up 12d:22h:28m:19s 2 192.168.106.3 192.168.106.4
    OGF-01 RICHETERRE 303 192.168.106.135 Down 2 192.168.106.3 0.0.0.0
    OGF-02 RICHETERRE 303 192.168.106.136 Down 2 192.168.106.3 0.0.0.0
    OGF-03 RICHETERRE 303 192.168.106.137 Down 2 192.168.106.3 0.0.0.0
    OGF-04 RICHETERRE 303 192.168.106.138 Down 2 192.168.106.3 0.0.0.0
    OGF-05 RICHETERRE 303 192.168.106.139 Down 2 192.168.106.3 0.0.0.0
    OGF-06 RICHETERRE 303 192.168.106.140 Down 2 192.168.106.3 0.0.0.0
    OTF-01 RICHETERRE 303 192.168.106.141 Down 2 192.168.106.3 0.0.0.0
    OTF-02 RICHETERRE 303 192.168.106.142 Down 2 192.168.106.3 0.0.0.0
    OTF-03 RICHETERRE 303 192.168.106.143 Down 2 192.168.106.3 0.0.0.0
    OTF-04 RICHETERRE 303 192.168.106.144 Down 2 192.168.106.3 0.0.0.0
    OTF-05 RICHETERRE 303 192.168.106.145 Down 2 192.168.106.3 0.0.0.0
    OTF-06 RICHETERRE 303 192.168.106.146 Down 2 192.168.106.3 0.0.0.0
    OW-A-01 RICHETERRE 303 192.168.106.20 Up 11d:23h:43m:42s 2 192.168.106.3 192.168.106.4
    OW-A-02 RICHETERRE 303 192.168.106.21 Up 1d:17h:26m:42s 2 192.168.106.3 192.168.106.4
    OW-A-03 RICHETERRE 303 192.168.106.22 Up 11d:23h:42m:42s 2 192.168.106.3 192.168.106.4
    OW-A-04 RICHETERRE 303 192.168.106.23 Up 11d:23h:42m:10s 2 192.168.106.3 192.168.106.4
    OW-A-05 RICHETERRE 303 192.168.106.24 Up 11d:23h:41m:34s 2 192.168.106.3 192.168.106.4
    OW-A-06 RICHETERRE 303 192.168.106.25 Up 11d:23h:41m:0s 2 192.168.106.3 192.168.106.4
    OW-A-07 RICHETERRE 303 192.168.106.26 Up 11d:23h:40m:28s 2 192.168.106.3 192.168.106.4
    OW-A-08 RICHETERRE 303 192.168.106.27 Up 11d:23h:40m:3s 2 192.168.106.3 192.168.106.4
    OW-A-09 RICHETERRE 303 192.168.106.28 Up 11d:23h:39m:45s 2 192.168.106.3 192.168.106.4
    OW-A-10 RICHETERRE 303 192.168.106.29 Up 11d:23h:39m:30s 2 192.168.106.3 192.168.106.4
    OW-A-11 RICHETERRE 303 192.168.106.30 Up 11d:23h:38m:58s 2 192.168.106.3 192.168.106.4
    OW-A-12 RICHETERRE 303 192.168.106.31 Up 11d:23h:38m:47s 2 192.168.106.3 192.168.106.4
    OW-A-13 RICHETERRE 303 192.168.106.32 Up 1d:23h:33m:55s 2 192.168.106.3 192.168.106.4
    OW-A-14 RICHETERRE 303 192.168.106.33 Up 11d:23h:38m:32s 2 192.168.106.3 192.168.106.4
    OW-A-15 RICHETERRE 303 192.168.106.34 Up 11d:23h:38m:20s 2 192.168.106.3 192.168.106.4
    OW-A-16 RICHETERRE 303 192.168.106.35 Up 11d:23h:38m:14s 2 192.168.106.3 192.168.106.4
    OW-A-17 RICHETERRE 303 192.168.106.36 Up 11d:23h:38m:7s 2 192.168.106.3 192.168.106.4
    OW-A-18 RICHETERRE 303 192.168.106.37 Up 11d:23h:37m:52s 2 192.168.106.3 192.168.106.4
    M = Mesh node
    Y = Mesh Recovery
    4 = WiFi Uplink
    AP Database
    OW-A-19 RICHETERRE 303 192.168.106.38 Up 11d:23h:38m:0s 2 192.168.106.3 192.168.106.4
    OW-A-20 RICHETERRE 303 192.168.106.39 Up 11d:23h:37m:46s 2 192.168.106.3 192.168.106.4
    OW-A-21 RICHETERRE 303 192.168.106.40 Up 1d:18h:42m:6s 2 192.168.106.3 192.168.106.4
    OW-B-01 RICHETERRE 303 192.168.106.41 Up 11d:23h:42m:59s 2 192.168.106.3 192.168.106.4
    OW-B-02 RICHETERRE 303 192.168.106.42 Up 1d:23h:12m:48s 2 192.168.106.3 192.168.106.4
    OW-B-03 RICHETERRE 303 192.168.106.43 Up 1d:21h:23m:16s 2 192.168.106.3 192.168.106.4
    OW-B-04 RICHETERRE 303 192.168.106.44 Up 11d:23h:42m:17s 2 192.168.106.3 192.168.106.4
    OW-B-05 RICHETERRE 303 192.168.106.45 Up 1d:19h:37m:57s 2 192.168.106.3 192.168.106.4
    OW-B-06 RICHETERRE 303 192.168.106.46 Up 11d:23h:41m:48s 2 192.168.106.3 192.168.106.4
    OW-B-07 RICHETERRE 303 192.168.106.47 Up 11d:23h:41m:30s 2 192.168.106.3 192.168.106.4
    OW-B-08 RICHETERRE 303 192.168.106.48 Up 11d:23h:41m:16s 2 192.168.106.3 192.168.106.4
    OW-B-09 RICHETERRE 303 192.168.106.49 Up 11d:23h:49m:10s 2 192.168.106.3 192.168.106.4
    OW-B-10 RICHETERRE 303 192.168.106.50 Up 18d:23h:26m:58s 2 192.168.106.3 192.168.106.4
    OW-B-11 RICHETERRE 303 192.168.106.51 Up 18d:23h:26m:7s 2 192.168.106.3 192.168.106.4
    OW-B-12 RICHETERRE 303 192.168.106.52 Up 11d:23h:38m:36s 2 192.168.106.3 192.168.106.4
    OW-B-13 RICHETERRE 303 192.168.106.53 Up 18d:21h:23m:2s 2 192.168.106.3 192.168.106.4
    OW-B-14 RICHETERRE 303 192.168.106.54 Up 18d:22h:7m:28s 2 192.168.106.3 192.168.106.4
    OW-B-15 RICHETERRE 303 192.168.106.55 Up 11d:20h:38m:24s 2 192.168.106.3 192.168.106.4
    OW-B-16 RICHETERRE 303 192.168.106.56 Up 1d:19h:4m:22s 2 192.168.106.3 192.168.106.4
    OW-B-17 RICHETERRE 303 192.168.106.57 Up 18d:23h:25m:40s 2 192.168.106.3 192.168.106.4
    OW-C-01 RICHETERRE 303 192.168.106.58 Up 18d:23h:38m:25s 2 192.168.106.3 192.168.106.4
    OW-C-02 RICHETERRE 303 192.168.106.59 Up 18d:23h:38m:41s 2 192.168.106.3 192.168.106.4
    OW-C-03 RICHETERRE 303 192.168.106.60 Up 1d:23h:27m:17s 2 192.168.106.3 192.168.106.4
    OW-C-04 RICHETERRE 303 192.168.106.61 Up 18d:23h:40m:33s 2 192.168.106.3 192.168.106.4
    OW-C-05 RICHETERRE 303 192.168.106.62 Up 18d:23h:40m:37s 2 192.168.106.3 192.168.106.4
    OW-C-06 RICHETERRE 303 192.168.106.63 Up 1d:18h:43m:36s 2 192.168.106.3 192.168.106.4
    OW-C-07 RICHETERRE 303 192.168.106.64 Up 18d:23h:41m:7s 2 192.168.106.3 192.168.106.4
    OW-C-08 RICHETERRE 303 192.168.106.65 Up 18d:23h:37m:43s 2 192.168.106.3 192.168.106.4
    OW-C-09 RICHETERRE 303 192.168.106.66 Up 18d:23h:38m:54s 2 192.168.106.3 192.168.106.4
    OW-C-10 RICHETERRE 303 192.168.106.67 Up 18d:23h:37m:46s 2 192.168.106.3 192.168.106.4
    OW-C-11 RICHETERRE 303 192.168.106.68 Up 18d:23h:38m:57s 2 192.168.106.3 192.168.106.4
    OW-C-12 RICHETERRE 303 192.168.106.69 Up 18d:23h:40m:41s 2 192.168.106.3 192.168.106.4
    M = Mesh node
    Y = Mesh Recovery
    4 = WiFi Uplink
    AP Database
    OW-C-13 RICHETERRE 303 192.168.106.70 Up 1d:18h:41m:9s 2 192.168.106.3 192.168.106.4
    OW-C-14 RICHETERRE 303 192.168.106.71 Up 18d:23h:39m:9s 2 192.168.106.3 192.168.106.4
    OW-C-15 RICHETERRE 303 192.168.106.72 Up 1d:18h:41m:8s 2 192.168.106.3 192.168.106.4
    OW-C-16 RICHETERRE 303 192.168.106.73 Up 18d:23h:37m:40s 2 192.168.106.3 192.168.106.4
    OW-D-01 RICHETERRE 303 192.168.106.74 Up 12d:0h:18m:27s 2 192.168.106.3 192.168.106.4
    OW-D-02 RICHETERRE 303 192.168.106.75 Up 12d:0h:18m:0s 2 192.168.106.3 192.168.106.4
    OW-D-03 RICHETERRE 303 192.168.106.76 Up 12d:0h:15m:46s 2 192.168.106.3 192.168.106.4
    OW-D-04 RICHETERRE 303 192.168.106.77 Up 12d:0h:15m:17s 2 192.168.106.3 192.168.106.4
    OW-D-05 RICHETERRE 303 192.168.106.78 Up 12d:0h:14m:23s 2 192.168.106.3 192.168.106.4
    OW-D-06 RICHETERRE 303 192.168.106.79 Up 12d:0h:13m:46s 2 192.168.106.3 192.168.106.4
    OW-D-07 RICHETERRE 303 192.168.106.80 Up 12d:0h:13m:19s 2 192.168.106.3 192.168.106.4
    OW-D-08 RICHETERRE 303 192.168.106.81 Up 12d:0h:12m:59s 2 192.168.106.3 192.168.106.4
    OW-D-09 RICHETERRE 303 192.168.106.82 Up 12d:0h:12m:29s 2 192.168.106.3 192.168.106.4
    OW-D-10 RICHETERRE 303 192.168.106.83 Up 12d:0h:11m:55s 2 192.168.106.3 192.168.106.4
    OW-D-11 RICHETERRE 303 192.168.106.84 Up 12d:0h:11m:29s 2 192.168.106.3 192.168.106.4
    OW-D-12 RICHETERRE 303 192.168.106.85 Up 12d:0h:11m:6s 2 192.168.106.3 192.168.106.4
    OW-D-13 RICHETERRE 303 192.168.106.86 Up 12d:0h:10m:47s 2 192.168.106.3 192.168.106.4
    OW-D-14 RICHETERRE 303 192.168.106.87 Up 1d:18h:32m:10s 2 192.168.106.3 192.168.106.4
    OW-D-15 RICHETERRE 303 192.168.106.88 Up 1d:18h:32m:11s 2 192.168.106.3 192.168.106.4
    M = Mesh node
    Y = Mesh Recovery
    4 = WiFi Uplink
    Total APs:179
    Arubamaster) [mynode] #show ap-group "JIN FEI"
    AP group "JIN FEI"
    Parameter Value
    Virtual AP Radio
    IDS profile default
    Parameter Value
    VLAN 300
    Forward mode bridge
    Allowed band all
    Deny time range N/A
    Mobile IP Enabled
    Anyspot profile N/A
    (Arubamaster) [mynode] #show ap system-profile "JIN FEI_apsys_ui"
    Parameter Value
    RF Band g
    Recovery Mode auto
    Native VLAN ID 300
    SNMP sysContact N/A
    SAP MTU N/A
    RAP MTU 1300 bytes
    LMS IPv6 N/A
    Backup LMS IPv6 N/A
    Heartbeat DSCP 0
    Management DSCP N/A
    Telnet Enabled
    Image URL N/A
    AP multicast aggregation Disabled
    AP POE mode shared
    GRE offload Enabled
    AP Deploy-hour N/A
  • 24.  RE: NO DHCP after connected to WIFI
    Posted Oct 02, 2019 02:31 AM
    what is the command to show switch port config?
  • 25.  RE: NO DHCP after connected to WIFI
    Posted Oct 02, 2019 03:01 AM
    show run interface 1 if on Aruba Switch, more or less the same on Cisco i believe
  • 26.  RE: NO DHCP after connected to WIFI
    Posted Oct 02, 2019 03:08 AM
    trusted
    trusted VLAN 1-4094
    no Poe
    switchport access VLAN 106
    switchport trunk allowed VLAN 1,96-98,106-108,300,320,310
  • 27.  RE: NO DHCP after connected to WIFI
    Posted Oct 02, 2019 03:14 AM
    The VLAN in the ap system profile should be 1.
    Parameter Value
    RF Band g
    Recovery Mode auto
    Native VLAN ID 300 <--- This should be 1.
  • 28.  RE: NO DHCP after connected to WIFI
    Posted Oct 02, 2019 03:20 AM
    when I set to VLAN 1, I don't get DHCP IP.
  • 29.  RE: NO DHCP after connected to WIFI
    Posted Oct 02, 2019 03:30 AM
    I think I've gone as far as I can with assisting here.
    I'm not convinved you have things configured as we have requested and/or the swithcport config you have shown us does not have the AP patched in.
    I would recommend re-reading all the recommendations in this thread and in the one I linked to get a better understanding of what should be configured and how bridge mode works.
  • 30.  RE: NO DHCP after connected to WIFI
    Posted Oct 02, 2019 03:49 AM
    show interfaces gigabitethernet 0/0/4 switchport
  • 31.  RE: NO DHCP after connected to WIFI
    Posted Oct 02, 2019 07:26 AM
    I was able to find the issue, the VLAN 300 wasn't tagged on the switch, after tagging on all my switch I was able to get IP from VLAN 300, Thank you for your kind help. much appreciated.
  • 32.  RE: NO DHCP after connected to WIFI
    Posted Oct 02, 2019 07:30 AM
    You mean - it wasn't tagged on the uplink of the switch? Because your config for gig 0/0/4 showed that it was tagged on that port.
    Glad you got it working.
  • 33.  RE: NO DHCP after connected to WIFI
    Posted Oct 02, 2019 07:33 AM
    no on the Aruba switch itself, I had VLAN 320 untagged with a tagged trunk trk1, I have tagged the ports to VLAN 300 and it was working.
  • 34.  RE: NO DHCP after connected to WIFI
    Posted Oct 02, 2019 03:46 AM
    Hmm - think you're missing this command:
    switchport trunk native vlan 1
    That is of course if that is the VLAN you're using for the IAP to get it's AP.
