Network Management
No DHCP - Aruba 2540 Switch
  • 1.  No DHCP - Aruba 2540 Switch
    Posted Mar 02, 2018 04:27 PM
    Hi All,
    I have purchased an Aruba 2540 switch for a client that requires it to be used for DHCP.
    I have upgraded firmware to 16.5 (latest) and the spec sheets show it supports DHCPv4 but I’m not able to see DHCP option in the GUI which is odd seeing as most online guides show it.
    I’ve downloaded the configuration guide from HP using the CLI to setup a DHCP pool. GUI shows the config file with DHCP enabled and the configuration for the pool.
    Do I need to assign the pool to default VLAN as at present no IP’s are being broadcast.
    Any help appreciated, as I’m somewhat stumped!
  • 2.  RE: No DHCP - Aruba 2540 Switch
    Posted Mar 02, 2018 10:20 PM
    please check if it support DHCP server or relay only? can you add ip on vlan interface?i think 2540 is purely L2 only.pls check
  • 3.  RE: No DHCP - Aruba 2540 Switch
    Posted Mar 03, 2018 02:58 AM
    Configuration document from Hpe definitely says this switch has DHCP server v4.
    I’ll try and add an IP address to VLAN.
  • 4.  RE: No DHCP - Aruba 2540 Switch
    Posted Feb 24, 2019 10:18 AM
    Hi Mr OCD,
    Is this issue resolved?
