There is nothing on Attribute Menu ?
ACEP / ACMX #107 / ACDX #1281
Original Message:
Sent: Jan 17, 2021 08:14 PM
Subject: No Endpoint "Updated At" Parameter
Did you ever get an answer for this?
Facing the same issue :-|
Cheers,
Chris Gruber
Original Message:
Sent: Feb 05, 2020 11:11 AM
Hello Community,
I want to clean up the endpoints using Cluster-Wide Clean Up Interval. For example, I want the "Unknown endpoints cleanup interval" change to 7 days.
Excerpt from manual for "Unknown endpoints cleanup interval" :
Specify the duration in number of days that ClearPass uses to determine when to start deleting unknown entries from the Endpoint repository.
Unknown entries are deleted based on the last Updated At value for each Endpoint.
For example, if this value is 7, then unknown Endpoints that do not have the Updated At value within the last 7 days (stale endpoints) are deleted.
The default value is 0 days. This indicates that no cleanup interval is specified.
So the cleanup interval based on endpoint's Updated At value. Althought all endpoints have "Added At", "Last Profiled At" but there is no "Updated At" parameter therefore the clean up interval do not effect.
How do I add "Updated At" to endpoints? My CPPM version 6.7.11
Best Regards!
