Network Management
No GUI after 8.0.4 upgrade
  • 1.  No GUI after 8.0.4 upgrade
    Posted Sep 11, 2014 07:26 AM
    After AMP update to 8.0.4 (VM) the GUI seems to be dead?
    I'm able to ssh to the VM and manage from CLI, but no gui.
    Any help?
    /niklas
  • 2.  RE: No GUI after 8.0.4 upgrade
    Posted Sep 11, 2014 07:36 AM
    Have you tried clearing your browser cache or using another browser?
  • 3.  RE: No GUI after 8.0.4 upgrade
    Posted Sep 11, 2014 07:53 AM
    Hi
    I have done two upgrades to 8.0.4, one in my lab and one to a customer.
    Both works like a charm, i think clearing the browser cache, as MattF suggests, will help you.
    Roar Fossen
  • 4.  RE: No GUI after 8.0.4 upgrade
    Posted Sep 11, 2014 07:59 AM
    No sadly. I have tried in 3 browsers and none of them works.
    any other suggestion?
    /niklas
  • 5.  RE: No GUI after 8.0.4 upgrade
    Posted Sep 11, 2014 08:04 AM
    Oki, if you haven't tried a reboot, do that.
    Otherwise try the amp_disable to stop det AMP application and do a amp_enable after that.
    This is done in the CLI after you connect to the AirWave with SSH.
    Roar Fossen
  • 6.  RE: No GUI after 8.0.4 upgrade
    Posted Sep 11, 2014 08:07 AM
    I've done that, and it did not help.
    is there anything else?
    /niklas
  • 7.  RE: No GUI after 8.0.4 upgrade
    Posted Sep 11, 2014 09:12 AM
    if you issue the command "daemons", are all services running?  Have you tried rebooting the VM?
  • 8.  RE: No GUI after 8.0.4 upgrade
    Posted Sep 11, 2014 09:57 AM
    Please open a support case.  Things to include:
    /var/log/upgrade/AMP-upgrade-version-history.log
    /var/log/upgrade/AMP-8.0.4-upgrade.log
    Things to check:
    # daemons
    (are there 12-15 daemons running?)
    # service httpd status
    (is apache running?)
    # service pound status
    (is the login web server running?)
    # root; svn info
    # amp_version
    (does URL from svn info match the version in amp_version? amp_version is a database field)
  • 9.  RE: No GUI after 8.0.4 upgrade
    Posted Sep 11, 2014 10:51 AM
    [root@wireless mercury]# daemons
    PID PPID PGID %CPU %MEM RSS ELAPSED CMD
    4150 1 4150 0.0 17.4 1045180 03:18:11 Daemon::AMONAggregator
    4182 1 4182 0.3 17.4 1043140 03:18:09 Daemon::APListCacher
    4186 1 4186 0.0 17.4 1043448 03:18:09 Daemon::APScanner
    4190 1 4190 0.0 17.4 1042740 03:18:09 Daemon::APWatcher
    4193 1 4193 0.0 17.4 1042984 03:18:08 Daemon::APWatcherPollNow
    4176 1 4176 0.0 17.4 1042744 03:18:09 Daemon::AlertD
    4333 1 4333 0.0 17.4 1045256 03:17:56 Daemon::AsyncLoggerClient
    4197 1 4197 0.0 17.4 1043544 03:18:08 Daemon::AsyncLoggerClient
    4200 1 4200 0.0 17.4 1042688 03:18:08 Daemon::ConfigPusher
    4207 1 4207 0.0 17.4 1042696 03:18:07 Daemon::ConfigVerifier
    4210 1 4210 0.0 17.5 1046908 03:18:07 Daemon::ConfigWrangler
    4220 1 4220 0.0 17.4 1042988 03:18:06 Daemon::DNSFetcher
    4213 1 4213 0.0 17.4 1044972 03:18:07 Daemon::DeviceEvent
    4217 1 4217 0.0 17.4 1043404 03:18:07 Daemon::DeviceHTTPSHandler
    4147 1 4147 0.0 17.4 1044736 03:18:11 Daemon::ExecUIQuery
    4024 1 4024 0.2 0.5 27824 03:18:19 Daemon::LowLevelServiceWatcher
    4226 1 4226 0.0 17.5 1047916 03:18:06 Daemon::PAPI
    4229 1 4229 0.0 17.4 1044428 03:18:06 Daemon::PAPIDecoder
    4339 1 4339 0.0 17.4 1045948 03:17:55 Daemon::PAPIDecoder
    4232 1 4232 0.0 17.4 1044468 03:18:05 Daemon::PAPIQueueConsumer
    4236 1 4236 0.0 17.4 1044792 03:18:05 Daemon::PEFProcessor
    4223 1 4223 0.0 17.4 1042964 03:18:06 Daemon::PartialConfigPusher
    4172 1 4172 0.4 17.4 1044368 03:18:10 Daemon::PerfCollector
    4125 1 4125 0.0 17.4 1043040 03:18:12 Daemon::PortGrabber
    4242 1 4242 0.0 17.4 1042700 03:18:05 Daemon::SNMPEnabler
    4245 1 4245 0.0 17.4 1043156 03:18:04 Daemon::SNMPFetcher
    4251 1 4251 0.0 17.4 1043856 03:18:01 Daemon::SNMPV2Fetcher
    4254 1 4254 0.0 17.4 1043856 03:18:01 Daemon::SNMPV2Fetcher
    4239 1 4239 0.0 17.4 1043576 03:18:05 Daemon::Scriptorium
    4039 1 4039 1.4 17.4 1045292 03:18:14 Daemon::ServiceWatcher
    4152 1 4152 0.0 17.4 1043864 03:18:10 Daemon::SwarmHandler
    4257 1 4257 0.3 17.5 1046208 03:18:01 Daemon::SyncD
    4267 1 4267 0.0 0.5 31908 03:18:00 Daemon::TranslationServer
    4131 1 4131 0.0 17.4 1043104 03:18:11 Daemon::TupleScheduler
    4128 1 4128 0.0 17.4 1042988 03:18:11 Daemon::TupleSpaces
    4315 1 4315 0.0 17.6 1053292 03:17:59 Daemon::UCCProcessor
    4302 1 4302 0.0 17.4 1043304 03:17:59 Daemon::WepKeySetter
    4298 4296 4296 0.6 2.6 154220 03:17:59 IGC
    4087 1 4086 0.3 0.7 39412 03:18:12 RabbitMQ
    12329 12328 12328 58.3 1.7 99916 00:11 VisualRF
    4043 1 4043 0.0 0.3 20056 03:18:12 airbus
    3988 1 3988 0.8 17.5 1049472 03:19:50 httpd_
    4161 1 4039 0.0 0.0 504 03:18:10 msgHandler
    4142 1 4142 0.1 0.2 9492 03:18:11 redis
    1546 1 1546 0.0 0.0 1756 03:31:02 rrdcached
    4249 1 4249 0.0 1.7 100500 03:18:01 snmptrapd
    [root@wireless mercury]# service httpd status
    httpd______________________________________ (pid 4339 4333 4315 4302 4257 4254 4251 4245 4242 4239 4236 4232 4229 4226 4223 4220 4217 4213 4210 4207 4200 4197 4193 4190 4186 4182 4176 4172 4152 4150 4147 4131 4128 4125 4039 4038 4037 4036 4035 4033 4032 3988) is running...
    [root@wireless mercury]# service pound status
    pound is stopped
    [root@wireless mercury]# service pound start
    Starting Pound: starting...
    /etc/pound.cfg line 14: SSL_CTX_use_PrivateKey_file failed - aborted
    [FAILED]
    [root@wireless mercury]# root; svn info
    Path: .
    Working Copy Root Path: /root/svn/mercury
    URL: http://svn.corp.airwave.com/usr/local/svnroot/mercury/tags/RELEASE_8_0_4
    Repository Root: http://svn.corp.airwave.com/usr/local/svnroot/mercury
    Repository UUID: 99f6a4a8-5413-0410-a0fb-e6b940866760
    Revision: 84390
    Node Kind: directory
    Schedule: normal
    Last Changed Author: aaron
    Last Changed Rev: 84390
    Last Changed Date: 2014-09-09 15:08:56 +0200 (Tue, 09 Sep 2014)
    [root@wireless mercury]# amp_version
    8.0.4
    [root@wireless mercury]# cat /var/log/upgrade/AMP-upgrade-version-history.log
    Thu Jun 12 09:08:37 GMT+1 2014 From: 7.7.9 To: 7.7.11 - Upgrade successful.
    Thu Jul 31 13:40:54 CEST 2014 From: 7.7.11 To: 8.0.1 - Starting upgrade.
    Thu Jul 31 13:47:37 CEST 2014 From: 7.7.11 To: 8.0.1 - Upgrade successful.
    Thu Sep 11 10:49:18 CEST 2014 From: 8.0.1 To: 8.0.4 - Starting upgrade.
    Thu Sep 11 10:57:24 CEST 2014 From: 8.0.1 To: 8.0.4 - Upgrade successful.
    what to do with the pound status??
  • 10.  RE: No GUI after 8.0.4 upgrade
    Posted Sep 11, 2014 11:28 AM
    The problem is my SSL certificate, i found this link AMP SSL and followed the guide, but still im getting this error on pound:
    /etc/pound.cfg line 14: SSL_CTX_use_certificate_chain_file failed - aborted
    [FAILED]
  • 11.  RE: No GUI after 8.0.4 upgrade
    Posted Sep 11, 2014 11:39 AM
    WEEEEEE
    it seems to me that i missed a step in the guide!
    It's working now!
    /Niklas
