Location Services
last person joined: 19 days ago
Location-based mobile app development and Bluetooth-based asset tracking with Meridian. Gathering analytics and business intelligence from Wi-Fi with Analytics and Location Engine (ALE).
no hostname shows with Airwatch 7.3 and clearpass 6.4 Integration
  • 1.  no hostname shows with Airwatch 7.3 and clearpass 6.4 Integration
    Posted Mar 13, 2015 05:59 PM
    I am having issues with the integration of Airwatch and Cleapass, both are On-Prem solutions and the all the information shows up from Airwatch except the hostname Column, has anyone exerianced this?I running Airwatch 7.3 and Cleapass 6.4
    There is a role set for Full API integration on the Airwatch side and all attributes are default on Aruba.
  • 2.  RE: no hostname shows with Airwatch 7.3 and clearpass 6.4 Integration
    Posted Mar 19, 2015 01:51 AM
    The hostname field is not one of the fields that is carried over from Airwatch.  If you have a helper address from that user VLAN pointing to ClearPass, it will obtain the hostname from the client's DHCP request and populate it.
  • 3.  RE: no hostname shows with Airwatch 7.3 and clearpass 6.4 Integration
    Posted Mar 30, 2015 06:18 PM
    Does the VLAN only need to be present on the Controller with the Helper address and not on Clearpass?
  • 4.  RE: no hostname shows with Airwatch 7.3 and clearpass 6.4 Integration
    Posted Mar 30, 2015 06:45 PM
    To follow up we have 3 VLANS and only one has the Helper address for all the devices using DHCP on that VLAN.
    Out of the 3 VLANS we only have one with a helper on the controller.
  • 5.  RE: no hostname shows with Airwatch 7.3 and clearpass 6.4 Integration
    Posted Mar 30, 2015 07:43 PM
    The layer 3 VLAN interface that your handheld devices are on needs a helper address pointing at clearpass.  It can be a secondary helper address that points at clearpass in addition to your original one that points at your DHCP server.  That will be enough to possibly populate the hostname into clearpass.
  • 6.  RE: no hostname shows with Airwatch 7.3 and clearpass 6.4 Integration
    Posted Mar 31, 2015 12:17 PM
    Thanks, we have a Layer 3 VLAN for all of our Corp Devices which is the only one that has the helper address, we also have a layer 2 VLAN which is the one pointing to the Clearpass servers, so i am assuming we also need a helper address for that as well?
  • 7.  RE: no hostname shows with Airwatch 7.3 and clearpass 6.4 Integration
    Posted Mar 31, 2015 12:37 PM
    you ONLY need an additional helper address on the subnet of the devices that need to be profiled.  That helper address should point to the clearpass server.
  • 8.  RE: no hostname shows with Airwatch 7.3 and clearpass 6.4 Integration
    Posted Mar 31, 2015 05:19 PM
    That worked for us thanks
  • 9.  RE: no hostname shows with Airwatch 7.3 and clearpass 6.4 Integration
    Posted Mar 31, 2015 06:23 PM
    To follow-up we added the IP helper Address on the L2 VLAN pointing to Clearpass, the L3 Helper is only pointing to DHCP, are you saying that we can also creater an IP Helper pointing to clearpass on top of the ip helper for DHCP for the L3 VLAN for any devices on the L3 VLAN to populate the hostname?
  • 10.  RE: no hostname shows with Airwatch 7.3 and clearpass 6.4 Integration
    Posted Mar 31, 2015 06:43 PM
    Yes.
