No Instant 4.3.2 on AP365 - Need help
  • 1.  No Instant 4.3.2 on AP365 - Need help
    Posted Apr 05, 2017 12:16 PM
    Hi, I was trying to set up Aruba 365 outdoor access point and it doesent show the possibility to use instant even though its datasheet says it should.
    It says its missing the image for it. Can someone tell me where I can get that image? Help very quickly would be very appriciated.
  • 2.  RE: No Instant 4.3.2 on AP365 - Need help
    Posted Apr 05, 2017 01:15 PM
    I am assuming you booted it up.
    Is it broadcasting an SSID?
  • 3.  RE: No Instant 4.3.2 on AP365 - Need help
    Posted Apr 05, 2017 09:49 PM
    InstantOS 4.3.2 does not seem to be available yet nor ArubaOS 6.5.2
    The latest available in the support site is 4.3.1.2 (InstantOS) from March 9th with no mention of IAP-365. For ArubaOS the latest is 6.5.1.3 from Feb. 16th.
    I guess you will need the TAC or your Local SE to help you getting a Beta release!
  • 4.  RE: No Instant 4.3.2 on AP365 - Need help
    Posted Apr 06, 2017 07:46 AM
    Thank you, that is the case. It just comes as a suprise because looking quickly at the data sheet it looks like it should work. Sad that it says nowhere that this won't be available until later. I would suggest editing the data sheet so people will know about this because it has made a quite a mess.
