Wired Intelligent Edge
  • 1.  No internal Communication
    Posted Feb 14, 2024 09:45 AM
    Trying to get AosCX 10.13.1000 running on eve-ng on Mac fusion.  While it installs and everything seems fine. I cannot ping the other end of a p2p link between two cx devices. cant work out for the life of me whats happening. I can ping local end. from each device only and yes they are connected together. any help would be appreciated.
  • 2.  RE: No internal Communication
    Posted Feb 15, 2024 02:53 AM
    I'm running EVE-NG on bear metal, but when you can boot up the simulators and log in it probably should work.
    Could you post your lab layout and configs?
    I don't have any probmles with the 10.13.1000
    Arne Opdal
  • 3.  RE: No internal Communication
    Posted Feb 16, 2024 02:15 AM
    Thanks, Issue somewhat sorted.  It seems like running two CX sims on Mac fusion is not a good idea. It takes some time for the services to come up.
    Moving to bare metal.
