Hi everyone. The lan switch works fine if used like a (stupid) unmanaged switch, but there's no way to reach the web page for configuring it; it seems that the switch can obtain an IP address from the DHCP Server.
I also reseted it by the reset switch, and esecuted many lan scanner software (Advanced_IP_Scanner, Look@lan, etc) but none finded it.
I disconnected the 1920S from the network and I reset it once again; I supposed it defaults acquire IP address 192.168.1.1 after 120 seconds. I connect a PC to the switch using an ethernet cable and I manually assigned this configuration to the PC's lan:
IP 192.168.1.12
subnet 255.255.255.0
no gateway
If I try to access the switch using a Web Browser pointing http://192.168.1.1, or ping it, the lan switch does not answer.
What can I do? Thanks for support!
#noip#jl382a#Webinterface#1920S
