Wired Intelligent Edge
  • 1.  no ip source-route
    Posted Nov 21, 2023 09:22 AM
    Hello all,
    kindly i need support as this command #no ip source-route  is used on cisco switches to disabl souce-route.how can I apply it on aruba cx6300 sw?
  • 2.  RE: no ip source-route
    Posted Nov 24, 2023 10:16 AM
    I think it was "no ip route" - under every physical interface that does not do routing...
    Lauri Laanenurm
    Aruba Technical Pre-Sales | Estonia & Latvia
    M: +372 53479830| email: llaanenurm@bdphpe.ee
    Paldiski mnt 29, ESTONIA
    WWW.ARUBANETWORKS.COM
    signatureImage
  • 3.  RE: no ip source-route
    Posted Nov 26, 2023 03:34 AM
    this command not exist any more on CX
  • 4.  RE: no ip source-route
    Posted Apr 17, 2025 12:29 PM
    Follow-up questions:
    - Since "no ip source-route" doesn't exist on CX any more, does it mean source routing is not supported on CX switches?
    - Or if source routing is supported on CX, then what is the CLI to disable it?
    Thank you!
  • 5.  RE: no ip source-route
    Posted Apr 18, 2025 05:54 AM
    Edited by vincent.giles Apr 18, 2025 05:54 AM
    No need to take care of disabling ip source-route on CX. This feature is not supported on AOS-CX.
