No layer 3 connectivity on access ports on Aruba mobility 620 controller.
  • 1.  No layer 3 connectivity on access ports on Aruba mobility 620 controller.
    Posted Mar 20, 2014 02:16 AM
    I am not able to access the controller on the access ports. I have DHCP server setup on 172.16.0.0/24 network. The controller's IP address is 172.16.0.254 on VLAN1 and the associated ports are F1/0  - F1/8 including the uplink. Though i am able to access the controller on my laptop using the uplink port but not through the access ports and they are all trusted. And I do have layer 2 connectivity on ports.
    I guess i am missing something basic here. But cant get my head around, what i am doing wrong.
  • 2.  RE: No layer 3 connectivity on access ports on Aruba mobility 620 controller.
    Posted Mar 20, 2014 02:30 AM
    When you plug the PC into the access port, can you please tell us what IP address/mask/gateway you get?
    Also, can you paste an output of the access ports running configuration, taken from a partial "show run" output at the CLI? Might be worth posting the uplink port output too.
    I assume you've got no ACLs on any of the wired ports (including the uplink)?
    You're right to have checked the "trusted" command, that's usually what is a common cause.
    When you say you can't access the controller, do you mean SSH/GUI? If you do, can you ping the controller IP? If you can, does a "arp -a" on the PC look correct in terms of the controller MAC-to-IP entry?
    Thanks.
  • 3.  RE: No layer 3 connectivity on access ports on Aruba mobility 620 controller.
    Posted Mar 20, 2014 04:20 AM
    I do not get any IP adress from DHCP. I have tried to establish L3 conencitivity by assigning static IP. But it still doesnt work.
    Please find the config file attached.
    No ACLs are configured.
    Yes, i mean SSH/GUI, though i am not able to ping the controller either.
    Attachment(s)
    txt
    Config.txt   2 KB 1 version
  • 4.  RE: No layer 3 connectivity on access ports on Aruba mobility 620 controller.
    Posted Mar 20, 2014 07:19 AM
    Your FE ports are on VLAN 2.   Does your controller have an IP on VLAN 2?
    From your output:
    interface fastethernet 1/0
            description "FE1/0"
            trusted
            trusted vlan 1-4094
            switchport access vlan 2
    Please run the following:
    show ip interface brief
    show vlan
  • 5.  RE: No layer 3 connectivity on access ports on Aruba mobility 620 controller.
    Posted Mar 20, 2014 08:45 AM
    Yes this is quite strange as i have deleted the VLAN2 as shown by in the show vlan output:
    #show vlan
    VLAN CONFIGURATION
    VLAN Description Ports AAA Profile
    1 Default FE1/0-7 GE1/8 Pc0-7 N/A
    #show ip interface brief
    Interface IP Address / IP Netmask Admin Protocol
    vlan 1 172.16.0.254 / 255.255.255.0 up up
    loopback unassigned / unassigned up up
    mgmt unassigned / unassigned down down
  • 6.  RE: No layer 3 connectivity on access ports on Aruba mobility 620 controller.
    Posted Mar 20, 2014 09:10 AM
    Please confirm what the port configuration is for 0-7.    Unless your output from ealier was incorrect, the ports were still configured for VLAN 2.
    show run | begin "interface fastethernet 1/0"
    If switchport access vlan 2 is still present, then change it.
    config t
    switchport access vlan 1
    ....repeat for 1/1-1/7
  • 7.  RE: No layer 3 connectivity on access ports on Aruba mobility 620 controller.
    Posted Mar 21, 2014 08:01 AM
    I have configured the ports with VLAN 2 , the updated config is shown below:
    #show running-config | begin "interface fastethernet 1/0"
    Building Configuration...
    description "FE1/0"
    trusted
    trusted vlan 1-4094
    interface fastethernet 1/1
    description "FE1/1"
    trusted
    trusted vlan 1-4094
    interface fastethernet 1/2
    description "FE1/2"
    trusted
    trusted vlan 1-4094
    interface fastethernet 1/3
    description "FE1/3"
    trusted
    trusted vlan 1-4094
    interface fastethernet 1/4
    description "FE1/4"
    trusted
    trusted vlan 1-4094
    speed 100
    duplex full
    interface fastethernet 1/5
    description "FE1/5"
    trusted
    trusted vlan 1-4094
    interface fastethernet 1/6
    description "FE1/6"
    trusted
    trusted vlan 1-4094
    interface fastethernet 1/7
    description "FE1/7"
    trusted
    trusted vlan 1-4094
    Unfortunately i am still unable to establish layer 3 conenctivity on access ports.  Please suggest!
  • 8.  RE: No layer 3 connectivity on access ports on Aruba mobility 620 controller.
    Posted Mar 24, 2014 03:46 AM
    Plug a PC into port fast-ethernet 0/1, leave it 1 minute, then get the following outputs from the console port...
    show port status
    show vlan
    show ip int brief
    show arp
    show ip dhcp bind
    show port stats
    Post the outputs on here please.
  • 9.  RE: No layer 3 connectivity on access ports on Aruba mobility 620 controller.
    Posted Mar 24, 2014 11:42 AM
    Here is the output:
    show port status
    Port Status
    Slot-Port  PortType  adminstate  operstate  poe      Trusted  SpanningTree  PortMode
    1/0        FE        Enabled     Up         Enabled  Yes      Disabled      Access
    1/1        FE        Enabled     Down       Enabled  Yes      Disabled      Access
    1/2        FE        Enabled     Down       Enabled  Yes      Disabled      Access
    1/3        FE        Enabled     Down       Enabled  Yes      Disabled      Access
    1/4        FE        Enabled     Down       N/A      Yes      Disabled      Access
    1/5        FE        Enabled     Down       N/A      Yes      Disabled      Access
    1/6        FE        Enabled     Down       N/A      Yes      Disabled      Access
    1/7        FE        Enabled     Down       N/A      Yes      Disabled      Access
    1/8        GE        Enabled     Down       N/A      Yes      Disabled      Access
    #show vlan
    VLAN CONFIGURATION
    #show arp
    Nothing!
    #show ip dhcp bind
    Nothing!
    #show port stats
    Port Statistics
    Port    PacketsIn  PacketsOut  BytesIn  BytesOut  InputErrorBytes  OutputErrorBytes  CRCErrors
    FE 1/0  908        0           91078    0         0                0                 0
    FE 1/1  0          0           0        0         0                0                 0
    FE 1/2  0          0           0        0         0                0                 0
    FE 1/3  0          0           0        0         0                0                 0
    FE 1/4  0          0           0        0         0                0                 0
    FE 1/5  0          0           0        0         0                0                 0
    FE 1/6  0          0           0        0         0                0                 0
    FE 1/7  0          0           0        0         0                0                 0
    GE 1/8  0          0           0        0         0                0                 0
    show ip route
    Codes: C - connected, O - OSPF, R - RIP, S - static
           M - mgmt, U - route usable, * - candidate default
    Gateway of last resort is Imported from DHCP to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from CELL to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from PPPOE to network 0.0.0.0 at cost 10
    C    172.16.0.0/24 is directly connected, VLAN1
  • 10.  RE: No layer 3 connectivity on access ports on Aruba mobility 620 controller.
    Posted Mar 24, 2014 05:36 PM
    Have you tried more than 1 PC?
    Have you tried rebooting the controller?
    If yes to both, log a TAC case. If no, do whatever you haven't.
  • 11.  RE: No layer 3 connectivity on access ports on Aruba mobility 620 controller.
    Posted Mar 24, 2014 07:24 PM
    You've got no route off the box; no default gateway.
    The way you've got things setup, there is only VLAN 1; the controller is on an isolated island.   Do you plan on uplinking this to your existing network and giving it an IP on that network?    Do you know what your LAN configurations look like?    We can't help you in setting up the controller to be on your LAN without additional information.
  • 12.  RE: No layer 3 connectivity on access ports on Aruba mobility 620 controller.
    Posted Mar 24, 2014 08:52 AM
    If you plug a PC in, does it get an IP on 172.16.0.0/24 per your DHCP pool on the controller?    Is .254 the gateway?   I also notice that you are NAT'ing VLAN 1.   This will NAT all user traffic to the controller IP (in your case 172.16.0.254).
    By looking at the config portion you shared, it looks like there is no L3 connectivity to your network.    How does the controller talk to any networks outside of itself?    It has only VLAN 1 defined (172.16.0.0/24).   The controller (and any connecting clients) have no knowledge of how to route outside of the controller.
    What does show ip route show for routes?
